2621 Router power question
asiegel
I have an old 2621 router that loses the config every time it loses power.  I assume that there is a replaceable battery.  Can anyone give me some guidance?  I assume that I'll have to power it down - replace battery - rebuild (again).  Is it a standard 3.2v BIOS (CR2032) battery?  Thanks!!
Ganesh Hariharan
battery?  Thanks!!
Hi ,
Normally these type of battery can "charge" themselves when you just plug them to a stable power source. There won't be a part number for this kind of thing.  You'll need to use a SmartNet contract to open a Cisco TAC case.  They'll be able to assist you with this.
Hope that help
If helpful do rate the post
Ganesh.H
