08-22-2012 09:52 AM - edited 03-07-2019 08:29 AM
I'm trying to turn off SSH version 1 & 2 to pass PCI compliance. Problem is, I cannot touch the VPN link between the two offices. I'm afraid the PKI certificate used for the VPN will be deleted if i zeroize the RSA key which seems to be the only way to stop the router responding on port 22.
Here is the stuff from the running config related to the crypto map:
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp policy 2
encr 3des
hash md5
group 2
crypto isakmp xauth timeout 15
crypto pki trustpoint TP-self-signed-4087584599
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-4087584599
revocation-check none
rsakeypair TP-self-signed-4087584599
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto dynamic-map SDM_DYNMAP_1 1
set security-association idle-time 28800
set transform-set ESP-3DES-SHA
reverse-route
crypto map SDM_CMAP_1 client authentication list sdm_vpn_xauth_ml_1
crypto map SDM_CMAP_1 isakmp authorization list sdm_vpn_group_ml_1
crypto map SDM_CMAP_1 client configuration address respond
crypto map SDM_CMAP_1 65535 ipsec-isakmp dynamic SDM_DYNMAP_1
I'm only CCNA so I'm not even sure if the certificate or RSA key is being used for the VPN link, but I can't tell from the running config that zeroizing it would be a good idea and not break the VPN.
I'm open to other ways of disabling SSH, as we are able to just connect using a console cable. But it looks like denying port 22 with an access-list doesn't even stop the router from responding to the port...
-Eric
08-22-2012 07:24 PM
Easiest way to block SSH, telnet, and all remote access to the router is the following:
line vty 0 4 (or 0 15, look at your config and see how many vty lines are configured)
transport input none
08-22-2012 08:08 PM
hi eric,
to my knowledge, 'zeroising' the RSA key will not break your VPN connection. the RSA key helps enable SSH and is for remote admin purpose.
but just to make sure, could you post your 'show crypto key mypubkey rsa' output?
08-22-2012 08:45 PM
Eric
When you say that you want to eliminate SSH on the router does that mean that you want to have no remote access to the router? The suggestion of transport input none will result in no remote access. If that is what you want then it is a good suggestion. If you want some remote access, then what kind of remote access do you want to allow? When we know that we can give you better advice about what to do.
Rick
08-23-2012 09:17 AM
% Key pair was generated at: 22:51:11 UTC Jul 13 2010
Key name: TP-self-signed-4087584599
Usage: General Purpose Key
Key is not exportable.
Key Data:
XXXXX
% Key pair was generated at: 17:32:34 UTC Aug 23 2012
Key name: TP-self-signed-4087584599.server
Usage: Encryption Key
Key Data:
XXXXXXX
Here is the output of the command "show crypto key mypubkey rsa".
I already have transport set to none, the port is still open however, even though trying to connect will give you a timeout.
We use teamviewer to remote into server, then use COM1 to get to the router, which is not ideal if you accadentally bring it down the internet, but I'm very wary about doing anything that might do that, or touch the VPN connection. Hence the reservation about zeroizing the RSA key and deleting those Certs.
output of "crypto key zeroize rsa":
% All RSA keys will be removed.
% All router certs issued using these keys will also be removed.
08-23-2012 09:24 AM
Ok I fixed it by limiting the vty to an ip access-list. So now the port is closed and we should pass.
I'd still like to know if zeroizing the key would blow up the VPN though... Just out of curiosity.
08-23-2012 06:47 PM
eric,
thanks for the show output and informing that you've turned off SSH successfully.
it is safe to say you can 'zeroize' your RSA keys. i will, however, correct myself on my initial comment on RSA keys with regards to VPN.
we could generate an RSA special-usage key which is used for IKE policies that have RSA authentication method:
http://www.cisco.com/en/US/docs/ios/12_2t/12_2t15/feature/guide/ft_key.html#wp1040590
please rate useful posts and mark the thread as resolved. thanks!
