2801 not issuing DHCP for my VLAN
nikalleyne
Hi Guys,
I'm testing a 2801 VoIP. I'm using the router on a stick concept to obtained previousl vlans (20 and 21) as well as I defined vlan 22 on the router. I wish to use the 4 switch ports on the router, so I configured a dhcp pool and assigned the interfaces to the vlan which the pool should server. However, I'm not getting any addresses on vlan 22. When I do a show dhcp server I have all 0s. Please see my configs below. All help appreciated
----- show dhcp server
DHCP server: ANY (255.255.255.255)
    Leases:   0
    Offers:   0      Requests: 0     Acks : 0     Naks: 0
    Declines: 0      Releases: 0     Query: 0     Bad: 0
------- Show Running-Config (Extract)
ip dhcp pool IT-VOICE
   network 192.168.22.0 255.255.255.0
   subnet prefix-length 8
   default-router 192.168.22.6
   domain-name maxxam.lab
   dns-server 192.168.2.8
   option 150 ip 192.168.22.253
interface FastEthernet0/0
description ***** CONNECTED TO LAN ******
no ip address
duplex auto
speed auto
auto qos voip trust
service-policy output AutoQoS-Policy-Trust
interface FastEthernet0/0.20
description **** CORP VLAN SUB INTERFACE *****
encapsulation dot1Q 20
ip address 192.168.20.253 255.255.255.0
interface FastEthernet0/0.21
description **** CORP-IT VLAN SUB INTERFACE *****
encapsulation dot1Q 21
ip address 192.168.21.253 255.255.255.0
interface FastEthernet0/0.22
description **** CORP-IT VOICE-VLAN SUB INTERFACE *****
encapsulation dot1Q 22
ip address 192.168.22.253 255.255.255.0
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet0/1/0
interface FastEthernet0/1/1
switchport access vlan 22
interface FastEthernet0/1/2
switchport voice vlan 22
interface FastEthernet0/1/3
interface Vlan1
no ip address
interface Vlan22
no ip address
------ show vlan-switch
VLAN Name                             Status    Ports
1    default                          active    Fa0/1/0
10   VLAN0010                         active
20   VLAN0020                         active
22   VLAN0022                         active    Fa0/1/1, Fa0/1/2, Fa0/1/3
100  VLAN0100                         active
1002 fddi-default                     active
1003 token-ring-default               active
1004 fddinet-default                  active
1005 trnet-default                    active
Does anyone see what may be wrong here.
Rick,
It is indeed not going to work( you have very good eyes- better than mine anyway  )
so doing a sh int f0/13 switchport will tell us exactly what the switches did with this command.
Regards.
Alain.
9 Replies 9
Giuseppe Larosa
Hello Nikalleyne,
you  should move L3 configuration to SVI interfaces if you have an etherswitch module installed on the router
interface vlan 22
instead of subif fas0/0.20, see the 4 Etherswitch ports as separated from the routed ports
your current configuration could work if one etherswitch would be configured as L2 trunk port and connected to fas0/0 but this would be a waste of interfaces.
Hope to help
Giuseppe
giuslar
Hi Giuslar,
I did just that and now the computer gets the IP, however, the phones do not. They are just stuck in "Configuring IP via DHCP". Also using Wireshark I do not see the option 150 in the bootp traces. Any other thoughts?
ip dhcp pool IT-VOICE-POOL
   domain-name mydomain.lab
no ip address
shutdown
duplex auto
speed auto
auto qos voip trust
no ip address
shutdown
duplex auto
speed auto
switchport mode trunk
ip dhcp relay information trusted
interface Vlan1
no ip address
interface Vlan22
   I think you misunderstood what Giuslar  meant .  You would have to move all your connections and routing info to  one the switchports . Create the layer3 SVI's for 20,21,22   and then trunk those vlans down to your lan switch . You would not use interface f0/0 at all , use one of the hwic switchports. You would then run your trunk from your hwic switchport to your lan switch .  It will not work  just putting vlan  22 on the switchports unless you are wiring the phones directly into those switchports .   Your default router in the dhcp pool should be .253 .
vlan database
vlan 20
vlan 21
vlan 22
Int vlan 20
ip address
Int vlan 21
ip address
Int vlan 22
ip address
Hwic switchport setup as a hardcoded trunk,  "switchport mode trunk " to the lan switch.
Hi Glen,
What you mentioed is exactly what I've done and it works for issuing dhcp. I configured f1/0/0 as a trunk and it learnt the other VLANS via VTP. I then use f0/1/1 to test whether my computer is getting IP addresse and it is. My other problem has to to do with the phones being stuck in Configuring IP via dhcp. So I think I have to research a bit more or go to another forum.
Thanks for the help guys, its much appreciated.
  If you are testing dhcp off those switchports be sure to add "spanning tree portfast"  to the ports before testing then see what happens.
That did not work. However, paying close attention to the Wireshark Capture should I not see the TFTP server when option 150 is advertised? I can see the router, DNS servers, etc. However, I see the Option 150 but not its value. I think I should be seeing the TFTP Server's ip addres. Am I correct?
I've used this document. http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00800942f4.shtml
I am not sure whether you have changed this or not. But when you showed part of the config you had this:
I do not think that it works to have the access vlan and the voice vlan have the same vlan number.
Rick
Rick
Rick,
Regards.
Alain.
Rick and Alain,
You guys, were both correct. However, I needed to change from
TO
I now have dial tone, thanks for paying attention for me. The funny thing is in my Packe tracer lab I did not have switchport access vlan22 and switchport voice configured so how I ended up doing it in the production environment I really don't know.
Cheers guys
