2811 Router Console problem
fasi25300
I am using cisco 2811 router for my lab it was working last night perfectly . morning time I just start my router and its not showing any thing on terminal window. no keys working even all fans working continously but no any fan is down on that time. I dun know how figureout this problem .
I use these troubleshootings.
1 - Baurt value change setting
2-  Console cable change
3-  used different kind of terminal softwares
4-  its not going on Romon mode
when I power off the router its just sho0ws the garbage values nothing else. I tried above solutions but didnot find any solution now please any body know about this problem please guide me will be very thankfull to you for this kindness
Many thanks in advance
M, Faisal
25 Replies 25
glen.grant
Sounds like a config register value issue and the console port speed has been changed.  Try multiple speed settings starting at 2400 baud ,then 4800 , 9600 , 19200, 38400,  double each setting up to 115200  and see if you get any response . If you finally get a response change the config register setting to either 0x2101 or 0x2102 .
Hi Glen
how are you thanx for your reply well I tried all baud values but its not showing any thing on console port even I can't use my kyeboard on console window. when I close my router it shows some garbage values nothing else i dunknow what is the fault please guide me .
regards
Muhammad Faisal
Muhammad ,
Are you using serial cable (9 pin) or USB to connect to your PC/Labtop?
If it is USB, usually the com port is 3 or 4 so try different com ports. try 1 through 5
Hi Reza
thanks for your reply. well I am using serial to USB cable and I have tried all ports 3 4 5 but the result is the same . even I tried to use this cable to other router and switches and its work fine .
Hi Muhammad ,
If you are sure that the cable is good, you are connected to the right Com port and your baud rate is correct, then turn off the router completely and wait a couple of minutes, connect the consol cable to the router and then turn it back on.  Let us know what happens
Hi Reza
Still the same problem but when ever I power down the router I can see garbage values nothing else console is showing connected but console window I can't type and use any key.
thanks
Muhammad,
Most of the time when you see garbage on the screen, the issue is the baud rate.
So, start from 9600 which is default and go up to 115200
Make sure evey time you change the baud rate to discoonect and reconnect. If you don't, the baud rate change will not be effective.  If you can use, Secure CRT or Putty which is free.
Reza
well I am using Teraterm for this connectivity do you mean that I nead to plug and unplug console cable every time when I am chaning the baud value ?
Yes, do that.  If you can use Putty, it is better application and free on the Internet, but Tera Term is fine too.
No worries about the fans noise right now]
Try to access with putty with different baud rates and also enable flowcontrol and check.
Since the cable is working with other devices,cable is not an issue.
Guru
reza
and more thing like when I start router previously all fans running for 2 mins and then noise of fans came down but now all fans running continiosly and its noise is not comming down .
Reza
I have checked all the step you said and still the same problem ...
Can you turn it off, wait for 10 minutes, connect the cable to it, tun it back on and post the output here?
reza
Now it shows nothing just cursor is blanking nothing else previously it was showing garbage value when I poweroff the router but now console window is completely blank.
