2811 traceback
Can any1 tell me if this is a s/w or h/w issue? Find attached the tech-support as well
1245794: Sep  8 16:14:48.943 EEST: %ALIGN-3-SPURIOUS: Spurious memory access made at 0x42232124z  reading 0x60
1245795: Sep  8 16:14:48.943 EEST: %ALIGN-3-TRACE: -Traceback= 0x42232124z 0x4223544Cz 0x422354C8z 0x41650098z 0x41650324z 0x41639E40z 0x4163A8C0z 0x4163AD24z
1245796: Sep  8 16:14:48.943 EEST: %ALIGN-3-TRACE: -Traceback= 0x42232310z 0x4223544Cz 0x422354C8z 0x41650098z 0x41650324z 0x41639E40z 0x4163A8C0z 0x4163AD24z
1245797: Sep  8 16:14:48.943 EEST: %ALIGN-3-TRACE: -Traceback= 0x42232314z 0x4223544Cz 0x422354C8z 0x41650098z 0x41650324z 0x41639E40z 0x4163A8C0z 0x4163AD24z
1245798: Sep  8 16:14:48.943 EEST: %ALIGN-3-TRACE: -Traceback= 0x42B0F64Cz 0x416500F4z 0x41650324z 0x41639E40z 0x4163A8C0z 0x4163AD24z 0x4163ADDCz 0x4163B00Cz
1245799: Sep  8 16:14:48.943 EEST: %ALIGN-3-TRACE: -Traceback= 0x42B0F66Cz 0x416500F4z 0x41650324z 0x41639E40z 0x4163A8C0z 0x4163AD24z 0x4163ADDCz 0x4163B00Cz
1245800: Sep  9 05:14:22.863 EEST: bad token 3, wanted TOK_NUMBER|TOK_PUNCT
1245801: Sep  9 07:59:28.104 EEST: %SYS-5-PRIV_AUTH_PASS: Privilege level set to 15 by lmsadmin on vty0 (10.0.0.63)
LOGBG#sh ver
Cisco IOS Software, 2800 Software (C2800NM-ADVSECURITYK9-M), Version 12.4(24)T3, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Tue 23-Mar-10 06:43 by prod_rel_team
ROM: System Bootstrap, Version 12.4(1r) [hqluong 1r], RELEASE SOFTWARE (fc1)
LOGBG uptime is 2 weeks, 1 day, 7 hours, 10 minutes
System restarted at 09:01:46 EEST Fri Aug 26 2011
System image file is "flash:c2800nm-advsecurityk9-mz.124-24.T3.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
Cisco 2811 (revision 53.51) with 247808K/14336K bytes of memory.
Processor board ID FCZ101470JQ
7 FastEthernet interfaces
1 Serial(sync/async) interface
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62720K bytes of ATA CompactFlash (Read/Write)
LOGBG#
TIA, Nicos Nicolaides
Contact the TAC support if there is already a bug fixed for this behaviour...If its there,they will advice you to upgrade to latest version where it is fixed...Else,they will file a bug
ankugarg
Level 7
Level 7
Hi Nicos,
Its a software issue for sure...File a bug
So what do i do? Upgrade to the latest version?
Thank you
