2821 IOS IP Base upgrade to Adv IP Serv
mmasis
Level 4
Level 4
Is there any posibility to do this upgrade on a router 2821 from IOS IP Base feature set upgrade to ADV IP Services?
I would appreciate any help!
Danilo Dy
Sure, you need minimum 256MB DRAM and 64MB FLASH which comes as default. Also, you need to purchase the ADV IP SERVICES as it is a feature upgrade
Dandy
