2821 router does not display anything on console after factory reset
HW05194
I just factory reset my router and when I go to power it on I do not see anything load up on putty. Not sure how to fix this I appreciate any help.
Thank you!
Make sure its connected to right port ( i am sure you do, just clarifying)
Hope the device is powered on, Can you confirm the Green Lights in front, then try to get another Console cable or try with another PC.
BB
Leo Laohoo
Double check console port settings.
Thanks for your reply. Just checked and the port settings are set to  9600, 8, 1 None and None
BB
Wow lol I actually reached back and took a closer look and noticed I had actually plugged it into the AUX port. Thanks a lot for your help!
