2821 Routing problem
whipcord1970
Community Member
I have a 2821 router with a hp switch connected to 0/0 and 0/1. Both switches have a pc connected, but I cannot ping from pc to pc. Doing a show arp in the router shows both pc's, but a show arp in either pc does not show the other pc but it does show the hp switch ip address with a '0000.0000.0000' mac address marked as invalid.
With debug arp I get a message '0000.0000.0000 wrong cable message.'
I get the impression the problem is at level 2 but I am certain all my cabling works ok, So the only other thing is the router is not allowing arp packets from 0/0 to 0/1 and back.Can anyone shed any light on this?
The relavent part of my config looks like this:
ip subnet-zero
ip cef
interface GigabitEthernet0/0
ip address 10.31.150.203 255.255.255.0
ip access-group 1 in
ip directed-broadcast
duplex auto
speed auto
no mop enabled
interface GigabitEthernet0/1
ip address 193.126.89.211 255.255.255.0
ip access-group 2 in
duplex auto
speed auto
no mop enabled
router rip
network 10.31.0.0
network 193.126.89.0
ip classless
ip route 10.31.150.0 255.255.255.0 193.126.89.209
ip route 193.126.89.0 255.255.255.0 10.31.150.210
ip http server
access-list 1 permit any
access-list 2 permit any
control-plane
Your DFGWs configured on the PCs are not the same ip addresses that you have configured on your router. If you want to use this router to route between these two subnets you will have to change your DFGWs on the PCs to match the routers interfaces. I hope this helps...
5 Replies 5
globalnettech
Level 9
Level 9
can you try and take the access lists off your interfaces ?
--> no ip access-group 1 in
duplex auto
speed auto
no mop enabled
--> no ip access-group 2 in
duplex auto
speed auto
no mop enabled
GNT
Hello GNT
I have tried removing access list from the interfaces, but this doesn't seem to have helped. The access list were as the router is in a development environment set up to 'permit any'.
amit-singh
Level 11
Level 11
First of all remove the static routes. You dont need them as you are already running rip and these networks are covered under that. Another thing I have noticed is that these routes have wrong next hop ip configured.
Please let us know the IP/mask/gateway set on your host PC's. Also check if the interfaces are up/up on the router or on the switch side.
HTH,
-amit singh
Both interfaces are up/up
PC1 IP address is 10.31.150.13 mask: 255.255.255.0
Gateway 10.31.150.1
PC 2 IP address is 193.126.89.232 mask:255.255.255.0
Gateway 193.126.89.1
Have removed static routes.
