Bookmark
Subscribe
1118
2900 password help
nate faulds
i recently bought a catalyst 2924 XL on craigs list (easy solution to what i needed), but the person i bought it from doesnt know the enable password on the console line, is there a way i could grab it or reset it??
need some help on this, Thanks.
Reza Sharifi
Hi Nate,
Just follow this link for password recovery procedurefor for Cisco Cat switches
http://www.cisco.com/en/US/products/hw/switches/ps628/products_password_recovery09186a0080094184.shtml
Reza
Reza Sharifi
Hi Nate,
Reza
this will wipe the config or reset the config or pass?
You can keep the current config but I would just wipe it and start fresh since this is new switch to you
i went to rename the config, it renamed, then i tried deleting the config.text left over, but the permsisions are read only, there a way i can delete the config file or format the config file/what i need to format to clear out the current config
