10-08-2016 06:51 PM - edited 03-08-2019 07:44 AM
hi all,
we have currently PSTN -> E1R2 2901 -> H323 line PBX -> phone. config is working both ways. only issue i have is when the PBX receives the call from the 2901 voice gateway, it receives the ANI/caller ID but with the Cisco Systems Inc after the ANI. so the phone display it show 555-1111 Cisco Systems Inc. can't find any reference on the router config for the Cisco Systems Inc. can I remove that so only the ANI shows?
using IOS 15.4. we also used a 2900 router during POC but it does not show the Cisco Systems Inc so i think it is a new IOS thing. will also provide the IOS version we used before once i have it confirmed. router config below
version 15.4
card type e1 0 0
no aaa new-model
network-clock-participate wic 0
network-clock-select 1 E1 0/0/0
ip cef
no ipv6 cef
isdn switch-type primary-net5
voice-card 0
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
no supplementary-service h450.2
no supplementary-service h450.3
supplementary-service h450.12
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
h323
sip
controller E1 0/0/0
framing NO-CRC4
ds0-group 0 timeslots 1-15 type r2-digital r2-compelled ani
cas-custom 0
country philippines use-defaults
controller E1 0/0/1
interface GigabitEthernet0/0
ip address 172.18.0.17 255.255.240.0
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip id CO ipaddr 172.18.0.2 1719
h323-gateway voip h323-id CO
h323-gateway voip bind srcaddr 172.18.0.17
voice-port 0/0/0:0
dial-peer voice 1 voip
description to PBX
destination-pattern .T
session target ipv4:172.18.0.2
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
dial-peer voice 2 pots
incoming called-number .T
direct-inward-dial
port 0/0/0:0
10-09-2016 06:40 PM
This is the Video Over IP community, you might want to move this other collaboration subjects area.
10-09-2016 07:11 PM
ye i was thinking creating it in the router section but thought more people in this community have more experience with the subject
