2911 Cisco Router using tftpdnld Command_Romon Recovery not working.
easamoah1
Hi guys, can someone please help me with my 2900 series router which has lost is IOS and its on the rommon mode, i have a copy of the IOS to load but what happens is after going through all the commands to load the IOS through tftp server, the it starts timing out at point of loading the IOS onto the router, ive tried a whole lot of steps through some videos i watched on youtube yet the router is not able to receive the IOS. After issuing this command eg: ( AFTER THE COMMANDS BELOW I ONLY GET THIS  ......... INSTEAD OF !!!!!!! THE DOT SIGNS LOOKS TO BE TIMMING OUT. AND EVENTUALLY, I HAVE TO TERMINATE IT SINCE ITS NOT ABLE TO UPLOAD THE IOS ON THE ROUTER.
CAN SOMEONE PLEASE HELP ME
rommon 6 > tftpdnld
TFTP_FILE: c2900-mz.151-4.M4.bin Invoke this command for disaster recovery only. WARNING: all existing data in all partitions on flash will be lost! Do you wish to continue? y/n: [n]:
johnlloyd_13
Level 9
Level 9
hi,
did you check if TFTP is allowed on the TFTP server/PC?
try to format the 2911 CF card on another router.
see helpful link with the same issue:
http://wannabelab.blogspot.com/2014/10/router-ios-upgrade-via-tftpdnld-and.html
