2948 Switch IOS Upgrade.
nickolaskimutai
I have a 2948 switch with an IOS that i am fing it difficult to use,most commands are not the conventional ones,Could any of you give some guidance on how i can do this upgrade?
glen.grant
If it is a 2948G then it is catos only and "cannot" be upgraded to IOS. You will have to learn how to use catos if you want to use this switch still, it is EOL at this point.
Jon Marshall
Is there anything in particular you are having problems with ?
