2950 configuration
dgiasson23
Community Member
I replaced a bay switch with a cisco 2950 and The 2950 has an IP address on VLAN 1 but I can not tracert to it or I can not telnet into it. All the traffic seems to go through it. Is there a setting that I am missing? Thanks sorry but new at this.
9 Replies 9
Prashanth Krishnappa
Do you have any devices in VLAN 1 on the switch? Is the VLAN interface up/up? If you have devices in VLAN 1, do the following
conf t
int vlan 1
no shut
If you still cannot reach it, attach outputs of
sh ver
sh run
sh int vlan 1
dgiasson23
Community Member
this worked thank you very much for your help
I have got a 2950 device, and I set fast ethernet 0/1 to 0/2 on Vlan 2 and fast ethernet 0/3 to 0/11 on vlan 3, and fast ethernet 0/12 is a trunk port.
how can I telnet to my device? I have not any Vlan1 ports for telneting!!
I guess there are two things you can do:
1. Configure at least one switchport on VLAN1.
# config terminal
(config)# interface FastEthernet 0/1
(config-if)# switchport access vlan 1
2. Configure the Vlan2 interface with an IP address:
# config terminal
(config)# interface Vlan 2
(config-if)# ip address 192.168.1.1 255.255.255.0
(config-if)# no shutdown
thanks for your answer 🙂
the second way is suitable for me 🙂
hi
I've bought a used 2950 Switch. I want to change it's configuration to the cisco's default configuration as a NEW 2950 is. What must I do?
you can do it by eraseing startup and runing configuration file... or you can also delet the vlan.dat file form switch...
and then reload the switch...
rate this post if it works
regards
Devang
dannyhorsch
Community Member
Somethimes the problem could be related that the Gateway on switch have not been set.
From the global config mode:
ip default-gateway x.x.x.x
for more info:
http://www.cisco.com/en/US/products/hw/switches/ps628/products_configuration_guide_chapter09186a00801cde76.html
