2950 Interface admin down
munawar.zeeshan
Level 4
Level 4
2950-01#sh ip int brief
Vlan1 unassigned YES NVRAM administratively down down
Vlan13 10.13.12.25 YES NVRAM up up
Vlan300 172.28.63.252 YES NVRAM administratively down down
Vlan310 172.28.64.252 YES NVRAM administratively down down
FastEthernet0/1 unassigned YES unset down down
FastEthernet0/2 unassigned YES unset down down
FastEthernet0/3 unassigned YES unset up up
FastEthernet0/4 unassigned YES unset down down
FastEthernet0/5 unassigned YES unset up up
FastEthernet0/6 unassigned YES unset down down
FastEthernet0/7 unassigned YES unset down down
FastEthernet0/8 unassigned YES unset down down
The problem with the above configuration is that when i noshut vlan 300, then vlan 13 goes administratively down.At a time only one interface out of the three (Vlan 13, Vlan 300, Vlan 310) remains up and active. No-shutting any interface results in the administratively down of all the other 2 interfces.
My version is
IOS (tm) C2950 Software (C2950-I6Q4L2-M), Version 12.1(22)EA8a, RELEASE SOFTWARE (fc1)
With 2950 you can have only ONE VLAN active with assigned IP address.
2950 is a layer 2 device.
I hope this helps.
Best regards.
Massimiliano.
I hope this helps.
Best regards.
Massimiliano.
aijaz802
Level 5
Level 5
2950 is a layer-2 switch, only one vlan interface can be up at any time....You can't have multiple vlan interfaces in this switch.
Please rate if it helps...
*aijaz*
