2951 ISR ROUTER BATTERY LOCATION
hamid khan
I am using 2951 ISR router Can any one help me locating its BATTERY as i need to replace it.
With Best Regards
Hamid Ali Khan
Mark Malone
HI Hamid
This is not recommended this is not a part an end user should be swapping like RAM or module , you could cause serious damage to your device
This is from Cisco DOCs
If the lithium battery in a Cisco 2900 or Cisco 3900 series ISR should fail, the router must be returned to Cisco for repair.
There is the danger of explosion if the battery is replaced incorrectly. Replace the battery only with the same or equivalent type recommended by the manufacturer.
Mark Malone,
Thanks for showing your concern.
Well the part of world I am living there is no Cisco Service available.
So if I send my console back to Cisco I will cost me double the price of Console.
Oh ok that's an issue alright , Unfortunatly i cannot fiond a doc that shows you where and how to change these exaclty and I would say that's due to the fact were not supposed to but saying that im sure its possible but as the above extract you would definitly want to make sure you have the same type of battery going in
