2960 Accessing problem- continous @ with no control
Tom Watts
Hi Mohamed, can you try a different problem such as Putty or SecureCRT?
Can you also affirm the same cable works on a different product? Do you use a USB Adapter? If using a USB Adapter, the drivers are updated? Also try a different computer if you have the option.
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
Hi Tom,
i tried Putty , but gave the same result and the switch was connectd directly to my laptop through console cable.
i tried to reset the switch , but in vain
