2960 IOS upgradation
vishalpatil86
Dear All,
I am trying to upgrade my cisco WS 2960 24 TC-L switch with the IOS image
c2960-lanbasek9-mz.122-55.SE6.bin and my existing IOS image is
c2960-lanbasek9-mz.122-50.SE5.bin. when i    am copying it to flash, it is getting copied but when i tried to boot it after entering command boot system c2960-lanbasek9-mz.122-55.SE6.bin , it gave me an error.
both flash dir and error are attahced herewith. Help me on this
Thanks in advance!!!
Could you copy following commands:
boot system flash:c2960-lanbasek9-mz.122-55.SE6.bin
do wr
end
reload
You need to instruct the file is on the device flash: Regarding your output it takes c29...... as medium.
Don't forget to rate usefull posts!
15 Replies 15
Something went wrong while setting the boot image.
Try the "archive" command instead, with that the boot-image is set automatically:
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/12.2_55_se/configuration/guide/swiosfs.html#wp1258453
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
Gregory Snipes
Level 4
Level 4
TFTP is not reliable and can result in transfer errors, you definitely have alot of errors based on your attached output. I would recommend trying to download the new IOS again using a reliable protocol like FTP or RCP or finding and correcting the scource of your errors.
If you get an archived copy of the IOS (the "with web based device manager" version) you would be able to use the archive command to perform the upgrade as well. The archive method downloads the IOS twice and compares them to ensure there were no bit errors. Then performs the full upgrade including setting all the proper boot statements for you.
Best of luck,
Greg
Leo Laohoo
The BIN file is corrupt.  Did you compare the MD5 hash?
Dear Leo,
I verified with MD 5 hash with original image. The image seemed fine...
One thing I observed while doing show flash, the running ios image doesn't have .bin extension
any suggestion??
The running image also has the ".bin" extention, but is installed inside a directory with the same name.
The boot-image is set incorrect. The easy way is to upgrade with the "archive"-command as with that the boot-image is set automatically. If you want to do it by hand, use the right url:
boot system flash:/c2960-lanbasek9-mz.122-55.SE6.bin
(in my first post I wrote incorrectly "upgrade"-command; sorry for that. Just corrected it.)
glen.grant
To me even though it looks like it had a lot of errors , it finished ok and that is the correct  size for that file and  it says "OK"  after the download.  It does a check on the file when its finished.   You can also use the verify command to check the file , try using  "boot system flash:c2960-lanbasek9-mz.122-55.SE6.bin. Also you have to remove the current boot statement if there is one .
DEar Glen,
I did that already and it is showing me in boot sequence also,
BOOT path-list      : c2960-lanbasek9-mz.122-55.SE6.bin
Config file         : flash:/config.text
Private Config file : flash:/private-config.text
Enable Break        : no
Manual Boot         : no
HELPER path-list    :
Auto upgrade        : yes
Auto upgrade path   :
NVRAM/Config file
      buffer size:   65536
Timeout for Config
          Download:    0 seconds
Config Download
       via DHCP:       disabled (next boot: disabled)
Enable Break        : no
Manual Boot         : no
HELPER path-list    :
Auto upgrade        : yes
Auto upgrade path   :
NVRAM/Config file
      buffer size:   65536
Timeout for Config
          Download:    0 seconds
Config Download
Any other suggestion??
Dear All,
I tried to upgrade through archive download command and received following error -
et0/1, changed state to up!!!!!!!!!!!!!!!!!!!!!!!!!!!
[OK - 9815360 bytes]
Loading c2960-lanbasek9-mz.122-55.SE6.bin from 172.16.10.203 (via Vlan10): !!!!!
Could not buffer tarfile...using multiple downloads
examining image...
%Tar checksum error in tftp://172.16.10.203/c2960-lanbasek9-mz.122-55.SE6.bin
%Error opening flash:update/info (No such file or directory)
ERROR: Image is not a valid IOS image archive.
Kindly advise
do wr
end
reload
  I agree there is no pointer in your boot statement pointing it to flash:  .  As in my previous note add
boot system flash:c2960-lanbasek9-mz.122-55.SE6.bin  .  Then remove the current  "no boot system:c2960-lanbasek9-mz.122-55.SE6.bin  .
Dear Davy,
It worked with below command -
do wr
end
reload
Ok, can you please post the output to the command "dir" please?
Directory of flash:/
    2  drwx         512   Mar 1 1993 00:02:22 +00:00  c2960-lanbasek9-mz.122-50.
SE5
  557  -rwx         107   Mar 1 1993 00:06:21 +00:00  info
  558  -rwx         676   Mar 1 1993 00:00:58 +00:00  vlan.dat
  559  -rwx     9815360   Mar 1 1993 00:10:31 +00:00  c2960-lanbasek9-mz.122-55.
SE6.bin
  560  -rwx        1919   Mar 1 1993 00:35:28 +00:00  private-config.text
  561  -rwx        3096   Mar 1 1993 00:13:37 +00:00  multiple-fs
  562  -rwx        4296   Mar 1 1993 00:35:28 +00:00  config.text
Can you post the output to the command "dir flash:c2960-lanbasek9-mz.122-50.SE5"?
