2960 IOS Upgrade from 12.2(46) to 12.2(58)SE1 using ciscoworks or any TFTP server
venkata dandu
Hi There
    Thanks in advance. We are trying to upgrade all our 2960 switches to the same image [12.2(58)SE1] using ciscoworks. Switches running image 12.2(55) are successfully getting upgraded but switches running 12.2(46) are failing half the way during the process of transfering the image. It fails even when i try it using CLI by connecting to the switch using telnet/ssh copying the image from a TFTP server.
    It successfully upgrades only when i try the same by connecting using a console cable. Is there any known bug or is there anything wrong in the process i was doing?
Regards;
Rams
glen.grant
  Check for bugs on with the 12.2.46 version . Sounds like a IOS issue  if 12.2.55 works .
