2960-L LAN Lite Configuration Guide
iswift
I can find no configuration guide for the LAN Lite feature set  - in particular QOS.
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960/software/release/12-2_37_ey/configuration/guide/scg/swqos.html#wp1331378
is for the legacy 2960, not the 2960-L.
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960l/software/15-2_6_e/configuration_guide/b_1526e_consolidated_2960l_cg/b_1526e_consolidated_2960l_cg_chapter_010111.html
is the correct model and IOS for me, but contains many commands that are not available in LAN Lite.
For instance you cannot use
auto qos
mls qos trust dscp
you cannot match on anything else than cos value in a class-map.
I suspect the documentation is for LAN BASE not LAN Lite.
Is there any documentation specifically for LAN Lite QOS ?
The only one listed here
https://www.cisco.com/c/en/us/support/switches/catalyst-2960-series-switches/products-installation-and-configuration-guides-list.html
is the old one above.
Ian
Mark Malone
try this commands will still be the same , most the general docs are for just the software version rather than attributed to any license type and contain all commands
Catalyst 2960 Switch Software Configuration Guide (LAN Lite Image)
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960/software/release/12-2_37_ey/configuration/guide/scg.pdf
