2960 logging trap 6 issue
Hi ,
Facing issue with 2960G switch , where its do not display "logging trap informational " in show running and show startup .where its showing all other levels from 0 to 5 and 7 after configuration and save commands .
the steps used to configure -
sw(confg)#loggig trap 6
sw(config)#exit
sw#wr
sw#show runn | i logging
sw#       --------------> (no match)
after config getting saved , it do not shows in show runn or in show startup while for all other levels it do show the config lines .
I tried the same on 12.55.SE release also but its same results .Please let me know is this a limitaion of this platform, is there any doc explaining the same for reference .
sh ver snap from switch-
SW2 uptime is 2 days, 5 hours, 3 minutes
System restarted at 08:29:28 IST Sat May 26 2012
System image file is "flash:c2960-lanbasek9-mz.122-44.SE6/c2960-lanbasek9-mz.122-44.SE6.bin"
cisco WS-C2960G-24TC-L (PowerPC405) processor (revision F0) with 61440K/4088K bytes of memory.
Last reset from power-on
1 Virtual Ethernet interface
24 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
64K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 00:26:51:48:BA:00
Motherboard assembly number     : 73-10015-07
Power supply part number        : 341-0098-02
--More--                           Model revision number           : F0
Motherboard revision number     : A0
Model number                    : WS-C2960G-24TC-L
System serial number            :
Top Assembly Revision Number    : B0
Version ID                      : V04
CLEI Code Number                : COMFX00BRA
Hardware Board Revision Number  : 0x01
Switch Ports Model              SW Version            SW Image
*    1 24    WS-C2960G-24TC-L   12.2(44)SE6           C2960-LANBASEK9-M
Configuration register is 0xF
SHCIL-MHDC-Ext-SW2#sh fil
SHCIL-MHDC-Ext-SW2#sh file sy
SHCIL-MHDC-Ext-SW2#sh file systems
File Systems:
     Size(b)     Free(b)      Type  Flags  Prefixes
*   32514048    22090240     flash     rw   flash:
           -           -    opaque     rw   vb:
Thanks for reply
amikat
The default trap level is "informational" and as such it is not displayed in the config file. Please see the reference for 12.2 IOS beneath:
http://www.cisco.com/en/US/docs/ios/12_2/debug/command/reference/dbfintro.html#wp1017299
You can check the trap level configured via the "sh logging" command.
Best regards,
Antonin
amikat
Best regards,
Antonin
