2960 Plus Series Switch in Automation
Translator
Community Manager
Community Manager
2960 Plus Series Model Switch WS-C2960 +24TC-L cannot enable the REP and Nor CIP function in the default Vlan.
The problem that I am facing is that using the Supervisory automation system: Indusoft + CLP + Cisco 2960 Switch we are experiencing slowness. The Network is internal and has no Internet access.
The network topology is fiber ring, enters the 1Gbic of the Switch and exits the other Gbic, enters the next Switch by replicating the same shape, so we use 15 Switch.
On the Switch, we've left with a fast port ethernet cable to Rockwell's CompactLogix L36ERM PLC.
Could you help me?
Translator
Community Manager
Community Manager
Hello
 This switch may not support REP.
I found this guide for IOS 15.2(6)E (Catalyst 2960-X Switch)
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960x/software/15_2_6_e/configuration_guide/b_1526e_consolidated_2960x_cg/b_1526e_consolidated_2960x_cg_chapter_01101011.html#concept_34975B810E6840169CCA365BA4B18CE2
 CIP has no reference to 2960 switch.
How is the CPU on the switches?
show proc cpu hist
