Redundant connection between 4321 ISR and switch
Translator
Community Manager
Community Manager
Please help - is there a way to establish a fault tolerant connection between the 4321 ISR router and the 2960 or IE2000 switch?
Writing bachelor's work, doing a simulation at Cisco Packet Tracer. The HSRP activation command is not accepted by the simulator.
6 Replies 6
 it is possible to use HSRP on Packet Tracer.  Can you share you project. You need to zip it first.
But the command 'standby' is available on L3 switches and routers:
Router(config)#in vlan 10
Router(config-if)#
Router(config-if)#
Router(config-if)#
Router(config-if)#stan
Router(config-if)#standby ?
<0-4095> group number
ip Enable HSRP and set the virtual IP address
ipv6 Enable HSRP IPv6
preempt Overthrow lower priority Active routers
priority Priority level
timers Hello and hold timers
track Priority Tracking
version HSRP version
Deepak Kumar
There are many ways to design fault tolerant connections with the mentioned devices, but I am assuming you are designing a flat layer 2 network. You can choose HSRP for it and it was also tested on PT. I think you are using an older version of PT or trying to add the same command with the wrong device or interface type.
Share your project if possible.
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Good afternoon!
Packet Tracer Ver. 8.1.1.022.
No, of course planned to connect at the level of 3 - with ispolzovaniemIP address.
And yes - you were right - I tried to connect the wrong interface type because
NIM-ES2-4 provides Layer 2 rather than Layer 3 ports, as you might think
Config page in PT.
hi,
can you upload the Packet Tracer project file?
Hello!
Please find the .pkt file attached.
But there is now redundant lines anymore - I do not have enough time.
Good afternoon!
Thank you for your questions.
The file format you want to attach is not available in the Community. Here is a list of available formats: jpg,gif,png,xlsx,tar,rtf,csv,ppt,pptx,mov,mp4,qt,wmv,doc,docx,pdf,jpeg,txt,xls,arf,zip
We also want to ask you to write your answers in Russian, since your content is already in automatic syndication and you do not need to translate it yourself into English.
Sincerely,
Community Manager
