2960 Plus VLAN Interface
shoegal2008
Community Member
Hi, i have a 2960 which i need to replace as it is now end of life, the replacement Cisco recommendes is the WS-C2960+24TC-L which is one of the new 260 Plus models, can you tell me if you can create a VLAN interface on this switch as it states that this is a layer 2 switch only??
Leo Laohoo
Yes, you can create VLAN interfaces.
