Giant frames on 6509 interface
Hello community,
our monitoring tools (LMS 4.1) are reporting high error rates on the interfaces interconnecting our backbone (6509-E running s72033-advipservicesk9_wan-mz.122-18.SXF17a.bin, located on 3 sites). Traffic passing through these interfaces is encrypted (SPA-IPSEC-2G). I believe that the high error rate was first reported when encryption was enabled (unfortunately I was on maternity leave back then, so I am not really sure about this).
What I see on the interfaces is a constant increment on giants, as well as an increase on rxOversizedPkt, when issuing the "show counters int" command. The error rate seems to increase with traffic increase.
I do not see any drops or any other CRCs. I am not sure if these giants have any impact on applications or user traffic... The interface mtu is 1600.
Should I be concerned??? I read that this might be a cosmetic bug (https://supportforums.cisco.com/document/23841/show-interface-command-reports-giants-trunks-cisco-catalyst-6500-switches-running).
Any thoughts or troubleshooting tips would be highly appreciated.
Thank you in advance,
Katerina
0 Replies 0
