2960 port is disabled
GuidoBarendse88
In the web-interface of the switch port Fe0/4 shows up orange an the description says that it is disabled.
When I use the show interface fa0/4 command it says the port is up
FastEthernet0/4 is up, line protocol is up (connected)
  Hardware is Fast Ethernet, address is 40f4.ec6c.1d84 (bia 40f4.ec6c.1d84)
  MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, media type is 10/100BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input never, output 00:00:00, output hang never
  Queueing strategy: fifo
  Output queue: 0/0 (size/max)
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts (0 multicasts)
     0 watchdog, 0 multicast, 0 pause input
     207 packets output, 16402 bytes, 0 underruns
     0 output errors, 0 collisions, 3 interface resets
Which one is the correct one?
Make that interface as port-fast and check
Somu
11 Replies 11
Jon Marshall
Guido
I would always trust the actual CLI on the switch. However the easiest solution is what is connected to fa0/4 and is it working ?
Jon
eagostin
What VLAN is the port configured on? Is that VLAN active and created?
Ed
amikat
The indication that port is disabled in Cisco Device Manager ("web-interface") is very often due to the spanning-tree port blocking status. In this case you can still see "interface up, line protocol up (connected)" status in the "sh int" command output. You can easily check if this is your case via the "sh spanning-tree" command.
Best regards,
Antonin
spanning-tree brother!!
you can issue show spanning-tree interface to see the stp status for all vlans.
Hope this helps
Cheers
Somu
show spanning-tree interface fa0/4
Vlan                Role Sts Cost      Prio.Nbr Type
VLAN0001            Desg LRN 19        128.4    P2p
show spanning-tree
VLAN0001
  Spanning tree enabled protocol ieee
  Root ID    Priority    32768
             Address     0001.4258.3dc0
             Cost        23
             Port        49 (GigabitEthernet0/1)
             Hello Time   2 sec  Max Age 20 sec  Forward Delay 15 sec
  Bridge ID  Priority    32769  (priority 32768 sys-id-ext 1)
             Address     40f4.ec6c.1d80
             Aging Time  15  sec
Interface           Role Sts Cost      Prio.Nbr Type
Fa0/2               Desg FWD 19        128.2    P2p
Fa0/4               Desg LRN 19        128.4    P2p
Fa0/9               Desg FWD 19        128.9    P2p
Fa0/10              Desg FWD 19        128.10   P2p
Does this mean there is no network connection on the 0/4 port? or that STP is nog working on this port?
If there is nothing connected to Fa0/4 port the interface should not stay at "line protocol up (connected)" status. Also LRN (learning) is STP only transition state and as such the interface should not stay at this one. Would you mind to post your interface Fa0/4 and STP configuration?
Best regards,
Antonin
I allready had edited my post by saying there is something connected on the port. It is an camera.
shutdown / no shutdown  ?
Somu
This works perfect.
What is the command the return to the original state?
Is it: no spanning-tree portfast?
