2960 problem
Muhammed AKYUZ
We are using 6500s a backbone and 3560s and 2960 as end user switches. We have PDUs and air conditioner for system room and they have Ethernet connections to 2960s. Yesterday power of air conditioners are gone for one second. Then Their web interfaces started not to work.We can ping air conditioners but web interfaces are not working. Then we reset the 2960s, air conditioner web interfaces are working now. What should the problem be? I know that if you can ping the device, everything else should work.
smahbub
Level 6
Level 6
Resetting the device causes the device to start from the initial setup and so all the self test for the device are performed which causes the device to work fine.The reason for the device facing this issue might be some loose connections in cabling or power connections.
