2960-S Supervisor TxQueue Drop Statistics
lcaruso
Level 6
Level 6
I have users connected to a 2960-S running 12.2(53r)SE complaining of slow network, specifically Internet performance while the upstream 2960 on the same vlan has no such issues, so I don't suspect link congestion on the face of things.
I'm planning on upgrading the code, but wanted to see what could be checked first. I'm seeing some drops but could use some tips on how to proceed from here as to what might be the issue. CPU is under 10% whenever I check it.
Thanks.
    Queue  0: 0
    Queue  1: 0
    Queue  2: 0
    Queue  3: 0
    Queue  4: 0
    Queue  5: 0
    Queue  6: 0
    Queue  7: 0
    Queue  8: 0
    Queue  9: 0
    Queue 10: 0
    Queue 11: 0
    Queue 12: 0
    Queue 13: 0
    Queue 14: 1315685992
    Queue 15: 0
2 Accepted Solutions
Leo Laohoo
Doesn't help.  The IOS you've quoted is the bootstrap and NOT the IOS version.
Can you please post the output to the following command:
1.  sh interface ;
2.  sh controll e ;
3.  sh version; and
4.  sh log
Ok, now the output is getting very disturbing.
1.  Link speed of Gi 0/11 is 10 Mbps.  Why is that?  What is connected to the far end?
2.  Under the output of the "sh interface Gi 0/11", look at "Total Output Drops".  This is generated when the switch tries to send data downstream (or down the wire) and the remote end is dropping packets.  This counter should never drop to zero.  It this event happens, the switch will record this and the counter increments.
3.  Under the output of the "sh controll e Gi 0/11" look under "Invalid frames, too large".  That's not good.
So what is connected to Gi 0/11???
Can you ask the person making the complaints to use another computer and see if he/she is exhibiting the same symptoms?
May I ask if you can run the following commands:
1.  Command:  test cable tdr int Gi 0/11;
2.  Wait for approximately 7 seconds;
3.  Command:  sh cable tdr int Gi 0/11; and
4.  Please post the output.
7 Replies 7
Leo Laohoo
1.  sh interface ;
2.  sh controll e ;
3.  sh version; and
4.  sh log
Thanks much for your reply! Hadn't seen one of those commands before!
lacking sleep...oh wait...so is everybody else in this business...
needs a reboot
needs an upgrade
I see a lot of multicasts
s-hw-2-1#sh int gi0/25
GigabitEthernet0/25 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is e804.62db.1899 (bia e804.62db.1899)
  Description: *** Uplink to hw-mc-3550-24-1 ***
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
  Keepalive not set
  Full-duplex, 1000Mb/s, link type is auto, media type is 10/100/1000BaseTX SFP
  input flow-control is off, output flow-control is unsupported
  Last input 00:00:00, output 00:00:28, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 1000 bits/sec, 2 packets/sec
     59005727 packets input, 43109590387 bytes, 0 no buffer
     Received 10434049 broadcasts (8956069 multicasts)
     0 watchdog, 8956069 multicast, 0 pause input
     33685706 packets output, 15044276646 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
s-hw-2-1#sh controll e gi0/25
     Transmit GigabitEthernet0/25             Receive
   2159382383 Bytes                        159929089 Bytes
     32886697 Unicast frames                48571756 Unicast frames
       508431 Multicast frames               8956115 Multicast frames
       290623 Broadcast frames               1477990 Broadcast frames
            0 Too old frames              3399750986 Unicast bytes
            0 Deferred frames              672471348 Multicast bytes
            0 MTU exceeded frames          148450015 Broadcast bytes
            0 1 collision frames                   0 Alignment errors
            0 2 collision frames                   0 FCS errors
            0 3 collision frames                   0 Oversize frames
            0 4 collision frames                   0 Undersize frames
            0 5 collision frames                   0 Collision fragments
            0 6 collision frames
            0 7 collision frames              299940 Minimum size frames
            0 8 collision frames            26385265 65 to 127 byte frames
            0 9 collision frames             3233677 128 to 255 byte frames
            0 10 collision frames            2032307 256 to 511 byte frames
            0 11 collision frames            1202392 512 to 1023 byte frames
            0 12 collision frames            3481180 1024 to 1518 byte frames
            0 13 collision frames                  0 Overrun frames
            0 14 collision frames                  0 Pause frames
            0 15 collision frames
            0 Excessive collisions                 0 Symbol error frames
            0 Late collisions                      0 Invalid frames, too large
            0 VLAN discard frames           22371100 Valid frames, too large
            0 Excess defer frames                  0 Invalid frames, too small
       299768 64 byte frames                       0 Valid frames, too small
     19569412 127 byte frames
      3147244 255 byte frames                      0 Too old frames
      1727353 511 byte frames                      0 Valid oversize frames
      1226616 1023 byte frames                     0 System FCS error frames
       883772 1518 byte frames                     0 RxPortFifoFull drop frame
      6831586 Too large frames
            0 Good (1 coll) frames
            0 Good (>1 coll) frames
s-hw-2-1#sh ver
Cisco IOS Software, C2960S Software (C2960S-UNIVERSALK9-M), Version 12.2(53)SE2, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Wed 21-Apr-10 06:08 by prod_rel_team
Image text-base: 0x00003000, data-base: 0x01B00000
ROM: Bootstrap program is Alpha board boot loader
BOOTLDR: C2960S Boot Loader (C2960S-HBOOT-M) Version 12.2(53r)SE, RELEASE SOFTWARE (fc3)
s-hw-2-1 uptime is 1 year, 42 weeks, 6 days, 1 hour, 50 minutes
System restarted at 15:59:11 CDT Thu Sep 30 2010
System image file is "flash:/c2960s-universalk9-mz.122-53.SE2/c2960s-universalk9-mz.122-53.SE2.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C2960S-24TS-S (PowerPC) processor (revision B0) with 131072K bytes of memory.
Processor board ID FOC1433X2WD
Last reset from power-on
2 Virtual Ethernet interfaces
1 FastEthernet interface
26 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : E8:04:62:DB:18:80
Motherboard assembly number     : 73-12423-06
Power supply part number        : 341-0328-01
Motherboard serial number       : FOC14340BXQ
Power supply serial number      : DCA1409M22C
Model revision number           : B0
Motherboard revision number     : A0
Model number                    : WS-C2960S-24TS-S
Daughterboard assembly number   : 73-11933-04
Daughterboard serial number     : FOC14341T1M
System serial number            : FOC1433X2WD
Top Assembly Part Number        : 800-32448-02
Top Assembly Revision Number    : A0
Version ID                      : V02
CLEI Code Number                : COMGJ00ARB
Daughterboard revision number   : A0
Hardware Board Revision Number  : 0x01
Switch Ports Model              SW Version            SW Image
*    1 26    WS-C2960S-24TS-S   12.2(53)SE2           C2960S-UNIVERSALK9-M
Configuration register is 0xF
s-hw-2-1#sh log
Syslog logging: enabled (0 messages dropped, 0 messages rate-limited, 0 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
    Console logging: level debugging, 23382 messages logged, xml disabled,
                     filtering disabled
    Monitor logging: level debugging, 0 messages logged, xml disabled,
                     filtering disabled
    Buffer logging:  level debugging, 23382 messages logged, xml disabled,
                     filtering disabled
    Exception Logging: size (4096 bytes)
    Count and timestamp logging messages: disabled
    File logging: disabled
    Persistent logging: disabled
No active filter modules.
    Trap logging: level informational, 23382 message lines logged
Log Buffer (4096 bytes):
e GigabitEthernet0/11, changed state to up
023345: Jul 26 14:47:36 CDT: %LINK-3-UPDOWN: Interface GigabitEthernet0/11, changed state to down
023346: Jul 26 14:47:38 CDT: %LINK-3-UPDOWN: Interface GigabitEthernet0/11, changed state to up
023347: Jul 26 14:47:39 CDT: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/11, changed state to up
023348: Jul 26 15:10:47 CDT: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/1, changed state to down
023349: Jul 26 15:10:48 CDT: %LINK-3-UPDOWN: Interface GigabitEthernet0/1, changed state to down
023350: Jul 26 15:10:51 CDT: %LINK-3-UPDOWN: Interface GigabitEthernet0/1, changed state to up
023351: Jul 26 15:10:52 CDT: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/1, changed state to up
023352: Jul 26 15:16:47 CDT: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/11, changed state to down
023353: Jul 26 15:16:49 CDT: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/11, changed state to up
023354: Jul 26 15:19:22 CDT: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/11, changed state to down
023355: Jul 26 15:19:23 CDT: %LINK-3-UPDOWN: Interface GigabitEthernet0/11, changed state to down
023356: Jul 26 15:19:25 CDT: %LINK-3-UPDOWN: Interface GigabitEthernet0/11, changed state to up
023357: Jul 26 15:19:26 CDT: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/11, changed state to up
023358: Jul 26 15:38:15 CDT: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/1, changed state to down
023359: Jul 26 15:38:16 CDT: %LINK-3-UPDOWN: Interface GigabitEthernet0/1, changed state to down
023360: Jul 26 15:39:39 CDT: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/11, changed state to down
023361: Jul 26 15:39:40 CDT: %LINK-3-UPDOWN: Interface GigabitEthernet0/11, changed state to down
023362: Jul 26 15:39:47 CDT: %LINK-3-UPDOWN: Interface GigabitEthernet0/11, changed state to up
023363: Jul 26 15:39:50 CDT: %LINK-3-UPDOWN: Interface GigabitEthernet0/11, changed state to down
023364: Jul 26 15:39:52 CDT: %LINK-3-UPDOWN: Interface GigabitEthernet0/11, changed state to up
023365: Jul 26 15:39:53 CDT: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/11, changed state to up
023366: Jul 26 15:57:48 CDT: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/3, changed state to down
023367: Jul 26 15:57:50 CDT: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/3, changed state to up
023368: Jul 26 16:19:03 CDT: %SYS-5-CONFIG_I: Configured from console by vty0 (10.10.223.1)
023369: Jul 26 16:35:54 CDT: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/11, changed state to down
023370: Jul 26 16:35:56 CDT: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/11, changed state to up
023371: Jul 26 16:37:38 CDT: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/11, changed state to down
023372: Jul 26 16:37:40 CDT: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/11, changed state to up
023373: Jul 26 16:38:13 CDT: %SYS-5-CONFIG_I: Configured from console by vty0 (10.10.223.1)
023374: Jul 26 16:40:08 CDT: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/4, changed state to down
023375: Jul 26 16:40:10 CDT: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/4, changed state to up
023376: Jul 26 17:02:18 CDT: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/11, changed state to down
023377: Jul 26 17:02:19 CDT: %LINK-3-UPDOWN: Interface GigabitEthernet0/11, changed state to down
023378: Jul 26 17:02:27 CDT: %LINK-3-UPDOWN: Interface GigabitEthernet0/11, changed state to up
023379: Jul 26 17:02:28 CDT: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/11, changed state to up
023380: Jul 26 17:03:18 CDT: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/11, changed state to down
023381: Jul 26 17:03:20 CDT: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/11, changed state to up
s-hw-2-1#
Hmmmm ....
I don't see any line errors on your Gi1/0/25, which I hope, is your uplink.  Now that's good news.
Now here are things that are getting quiet "interesting".
Firstly, your IOS.  12.2(53)SE (and anything in the "53"), is an IOS I would NOT use.  Period.
Next, I don't want to call you a "liar" but I nearly did.  Look at your "sh logs".  I have two questions:
1.  Did you get this "sh log" output from a 2960S?  Look at the interface, it is showing that it could be a non-2960S or a non-3750G/E/X.
2.  Is the client having issues connected to Gi0/11?
Can you please further post the following output:
1.  sh interface ; and
2.  sh controll e
Sorry about the lag time. This site went offline last night just as I attempted my post. Then when it came back online, I could not login.
I can assure you I did.
I wasn't yet provided the , but let's assume it's gi0/11 as it appears likely. Thanks.
s-hw-2-1#sh int gi0/11
GigabitEthernet0/11 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is e804.62db.188b (bia e804.62db.188b)
  Description: User Access
  MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
  Keepalive set (10 sec)
  Full-duplex, 10Mb/s, media type is 10/100/1000BaseTX
  Last input never, output 00:00:00, output hang never
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 351
     4731239 packets input, 621556977 bytes, 0 no buffer
     Received 79724 broadcasts (16622 multicasts)
     0 runts, 19 giants, 0 throttles
     19 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 16622 multicast, 0 pause input
     14753576 packets output, 10011869811 bytes, 0 underruns
s-hw-2-1#sh controll e gi0/11
  Transmit GigabitEthernet0/11             Receive
1421937036 Bytes                        621556977 Bytes
   8719754 Unicast frames                 4651515 Unicast frames
   5136702 Multicast frames                 16622 Multicast frames
    897139 Broadcast frames                 63102 Broadcast frames
         0 Too old frames               611275655 Unicast bytes
         0 Deferred frames                4792405 Multicast bytes
         0 MTU exceeded frames            5348636 Broadcast bytes
         0 3 collision frames                  19 Oversize frames
         0 7 collision frames             3862892 Minimum size frames
         0 8 collision frames              310945 65 to 127 byte frames
         0 9 collision frames              132197 128 to 255 byte frames
         0 10 collision frames             121005 256 to 511 byte frames
         0 11 collision frames             205777 512 to 1023 byte frames
         0 12 collision frames              98423 1024 to 1518 byte frames
         0 Late collisions                     19 Invalid frames, too large
         0 VLAN discard frames                  0 Valid frames, too large
   6355271 64 byte frames                       0 Valid frames, too small
    999963 127 byte frames
    413354 255 byte frames                      0 Too old frames
    455073 511 byte frames                      0 Valid oversize frames
    548471 1023 byte frames                     0 System FCS error frames
   5981463 1518 byte frames                     0 RxPortFifoFull drop frame
         0 Too large frames
s-hw-2-1#
The system on that port Gi0/11 is probably a really old pc. I'll get more information next week and ask if more than one person is having the problem.
I did the upgrade so all stats will be based on
WS-C2960S-24TS-S   15.0(1)SE3            C2960S-UNIVERSALK9-M
Thanks much for the cable test commands. Results look normal.
s-hw-2-1#sh cable tdr int Gi 0/11
TDR test last run on: July 27 21:52:04
Interface Speed Local pair Pair length        Remote pair Pair status
Gi0/11    10M   Pair A     16   +/- 0  meters N/A         Normal
                Pair B     18   +/- 0  meters N/A         Normal
                Pair C     17   +/- 0  meters N/A         Normal
                Pair D     17   +/- 0  meters N/A         Normal
After the upgrade and running for a full day on the new code after reboot, have no invalid frames too large but (again) have Total output drops of 21
Odd thing about this 10Mb/s system, whatever it is, look at the proportion of multicast frames xmit to everything else
s-hw-2-1#sh controll e Gi0/11
      5504814 Bytes                                0 Bytes
          652 Unicast frames                       0 Unicast frames
        49952 Multicast frames                     0 Multicast frames
        13834 Broadcast frames                     0 Broadcast frames
            0 Too old frames                       0 Unicast bytes
Ok, I'll be checking the client at the remote end.  10 Mbps and you still get output drops does not sound right.
