09-07-2016 11:04 PM - edited 03-08-2019 07:20 AM
Hello experts,
I have 2 types of switch 2960, they face a problem with CPU:
Switch Ports Model SW Version SW Image
* 1 28 WS-C2960X-24PS-L 15.0(2a)EX5 C2960X-UNIVERSALK9-M
* 1 52 WS-C2960X-48FPS-L 15.2(2)E3 C2960X-UNIVERSALK9-M
SW-2960#sh proc cpu sort | e 0.0
CPU utilization for five seconds: 37%/0%; one minute: 37%; five minutes: 37%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
160 89656467 8594277 10432 22.44% 22.41% 22.41% 0 Hulc LED Process
171 1082506 68557 15789 0.23% 0.25% 0.23% 0 HQM Stack Proces
Anybody can tell me what is "Hulc LED Process" and how can I fix it.
I really appreciate any help.
Thanks so much.
09-07-2016 11:45 PM
HULC is a known bug that runs across several platform of 2/3ks and effects a lot of different versions of ios been around a while
Theres a lot of posts on it already for 2960x and other platforms below in support link
You need to find an image its not effected by it 12.2(55)SE8 I think was one of them , there are other options that have worked for some like shutting unused ports and reloading it.
https://supportforums.cisco.com/search/site/hulc?f[0]=sm_og_group_ref%3Anode%3A6016&f[1]=is_top_level%3A5411
This is one of the bug ids if you put 2960 and hulc into google you will see a lot more
Hulc LED Process uses 6-23% CPU on Catalyst 2960/2960S/2960X switch
CSCtg86211
Description
Symptom:
Hulc LED Process uses 6-23% CPU on Catalyst 2960/2960S/2960X 24 or 48-port switch.
Conditions:
The CPU utilization for Hulc LED Process will be in the 6-23% range for the
Catalyst 2960 series like 2960, 2960S, 2960X switch models.
For WS-C2960X-48LPS-L which is 48ports PoE 2960X switch Hulc LED Process
Could reach about 22%-23%.
The is seen in 12.2(50)SE03 or later releases.
Workaround:
This is an expected behavior and there is no workaround.
Further Problem Description:
The "Hulc LED" process does following tasks:
- Check Link status on every port
- If the switch supports POE, it checks to see if there is a Power Device (PD)
detected
- Check the status of the transceiver
- Update Fan status
- Set Main LED and ports LEDs
- Update both Power Supplies and RPS
- Check on system temperature status
09-08-2016 07:49 PM
Hi Mark,
Thanks for your comment. I tried reload it but not help. I think I will ask for permission to change the images.
09-12-2016 01:43 AM
Hi Mark,
I upgraded IOS from 15.0(2a)EX5 to 15.2(5)E. But the CPU is still high. Do you have any idea?
09-08-2016 09:24 PM
Upgrade the IOS to 15.2(4)E train (or later).
09-08-2016 11:22 PM
09-12-2016 01:44 AM
Hi Leo,
09-12-2016 04:45 PM
Post the complete output to the following commands:
1. sh version;
2. sh proc cpu sort | ex 0.00
09-12-2016 06:07 PM
Firstly, I upgraded to 15.2(5)E, but it's not help. Then, I tried other image (15.2(4)E2).
SW-2960#sh ver
Cisco IOS Software, C2960X Software (C2960X-UNIVERSALK9-M), Version 15.2(4)E2, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2016 by Cisco Systems, Inc.
Compiled Mon 27-Jun-16 08:49 by prod_rel_team
ROM: Bootstrap program is C2960X boot loader
BOOTLDR: C2960X Boot Loader (C2960X-HBOOT-M) Version 15.2(3r)E1, RELEASE SOFTWARE (fc1)
cisco WS-C2960X-24PS-L (APM86XXX) processor (revision K0) with 524288K bytes of memory.
Processor board ID FCW1951B1SC
Last reset from reload command
2 Virtual Ethernet interfaces
1 FastEthernet interface
28 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 0C:11:67:61:65:80
Motherboard assembly number : 73-16694-04
Power supply part number : 341-0528-01
Motherboard serial number : FOC19506HCT
Power supply serial number : LIT194704KU
Model revision number : K0
Motherboard revision number : B0
Model number : WS-C2960X-24PS-L
Daughterboard assembly number : 73-14200-03
Daughterboard serial number : FOC19500NX6
System serial number : FCW1951B1SC
Top Assembly Part Number : 68-100472-01
Top Assembly Revision Number : B0
Version ID : V03
CLEI Code Number : CMMLR00ARC
Daughterboard revision number : A0
Hardware Board Revision Number : 0x18
* 1 28 WS-C2960X-24PS-L 15.2(4)E2 C2960X-UNIVERSALK9-M
Configuration register is 0xF
CPU utilization for five seconds: 30%/0%; one minute: 30%; five minutes: 30%
163 9993925 1428082 6998 14.94% 15.00% 15.00% 0 Hulc LED Process
175 89399 11422 7826 0.11% 0.13% 0.11% 0 HQM Stack Proces
09-12-2016 06:30 PM
30% is perfect.
I don't see anything wrong with this value. I would get worried if the CPU value goes higher than 60%. Anything this low is just right.
09-12-2016 06:39 PM
09-13-2016 12:16 AM
Yes I agree with Leo if switch is running at that low cpu theres nothing to worry about , I have seen it take up to 25% on devices , if you cant find an ios its fixed in you could ask TAC to provide one , the v15 ios are not as stable for bugs as the v12 , you should be able to check the release notes to see if the caveat is there before downloading another ios either
09-13-2016 01:01 AM
Thanks so much, Leo and Mark.
