IP Multicast for IP TV
kamlenegi
Hi all,
Can someone tell me require configuration in Nexus 9K or Cisco 2960x access switch configuration for multicast to run IP TV. I have tested for AirPlay the below command.
core:
IP Multicast-routing
interface vlan vlan-id
ip pim sparse-mode
Access Switch
ip igmp snooping vlan vlan-id
What would be the recommended configuration for IP TV.
Kamlesh
13 Replies 13
Furose M
Level 3
Level 3
where is the multicast source and destination are connected to?
are they in same vlan or different vlans?
Source is IP TV connected in Access Switch Cisco 2960x and Destination is their server connected to Nexus 9000.
Kamlesh
are they in same vlan?
yes it is in same vlan.
Kamlesh
whatever you have should be enough, provided there is an ip address present in N9k to act as querier.
Yes, they are providing some IP address for servers.
Kamlesh
Hi Furose,
If multicast source & destination is in different VLAN, then what would be recommended config.
Kamlesh
with this simple setup, you would have to enable "IP PIM sparse-mode" in both the Vlans' SVI, configure a RP on the same device (N9k).
Thanks Furose,
What would be the access switch configuration, is it
or igmp ver 3 required
Kamlesh
Hi Kamlesh,
no config is required on the access switch. IGMP snooping is enabled by default and you dont need IGMP v3 here (unless you are using Source-specific multicasting in your network)
Thanks Furose,
I will do configuration and will update you.
Kamlesh
Thanks Furose,
It is working.
Kamlesh
Hi Furose,
IP TV is working perfect when connect to Core switch but when connecting access switch, quality is degrade. Access switch showing output is :
Do we require any other configuration in Access switches.
Global IGMP Snooping configuration:
IGMP snooping                : Enabled
IGMPv3 snooping (minimal)    : Enabled
Report suppression           : Enabled
TCN solicit query            : Disabled
TCN flood query count        : 2
Robustness variable          : 2
Last member query count      : 2
Last member query interval   : 1000
Vlan 81:
IGMPv2 immediate leave              : Disabled
Multicast router learning mode      : pim-dvmrp
CGMP interoperability mode          : IGMP_ONLY
