2960 switch configuration issues
Tom.Church
Community Member
We have multiple 2960 in the field and are having issue holding the Vlan1 ip address. Seems that after a period of time if the switch gets rebooted 1 or 2 things happen. The switch loses it's entire config or the ip address that is assigned to the vlan1 interfaces disappears. All of the ones in the field have the same configuration. Has anyone heard about this? The IOS code is:
c2960-lanbasek9-mz.122-25.FX.bin
7 Replies 7
Kevin Dorrell
Level 11
Level 11
I have not heard of such a problem. I presume you do save your configurations (copy run start) each time you do any changes?
Or do you perhaps configure from a TFTP server? Do you have service config anywhere in your configuration?
What is in your config register? Could you do a show version please?
Kevin Dorrell
Luxembourg
Please note the confreg 0xF
Cisco IOS Software, C2960 Software (C2960-LANBASEK9-M), Version 12.2(25)FX, RELE
ASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Wed 12-Oct-05 23:14 by yenanh
ROM: Bootstrap program is C2960 boot loader
BOOTLDR: C2960 Boot Loader (C2960-HBOOT-M) Version 12.2(25r)SEE1, RELEASE SOFTWA
RE (fc1)
2960_68171 uptime is 42 minutes
System image file is "flash:c2960-lanbasek9-mz.122-25.FX.bin"
to comply with U.S. and A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
cisco WS-C2960-24TT-L (PowerPC405) processor (revision B0) with 61440K/4088K byt
es of memory.
Processor board ID FOC1108Z5D8
Last reset from power-on
1 Virtual Ethernet interface
24 FastEthernet interfaces
2 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
64K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 00:1B:53:36:0E:00
Motherboard assembly number : 73-10390-03
Power supply part number : 341-0097-02
Motherboard serial number : FOC11072R9Z
Power supply serial number : DCA11038B6F
Model revision number : B0
Motherboard revision number : C0
local laws, return this product immediately.
Model number : WS-C2960-24TT-L
System serial number : FOC1108Z5D8
Top Assembly Part Number : 800-27221-02
Top Assembly Revision Number : C0
Version ID : V02
CLEI Code Number : COM3L00BRA
Hardware Board Revision Number : 0x01
Switch Ports Model SW Version SW Image
* 1 26 WS-C2960-24TT-L 12.2(25)FX C2960-LANBASEK9-M
Configuration register is 0xF
rick.savoy
Community Member
Hi Tom, I have a similar scenario. I have 2950's and 2960's that either lose their configurations or simply stop responding to a ping although they continue to function as a switch when that happens. Keep in mind the config could also be erased by holding in the mode button for too long. I have not seen any remedy for a few months now on this forum as to why they stop responding. A Cisco case may have to be opened to get the right attention, unless someone can reply to this thread?
We have not seen this problem and we have a lot of 2950's but it rings a bell and I think it was a code issue if the code is really old. We are running 12.1.22ea10 and have been for some time and have not seen an issue , my reccomendation would be to upgrade the code to the latest release. Have never seen a box lose the config unless you have unstable power where it goes down , starts come back and then quickly goes down again , we have seen a router or 2 where it loses the config in nvram.
barry.rawcliffe
Community Member
Hi Tom,
I have an almost identical issue in that I am losing all configuration and going back to the initial config dialogue.
Cisco IOS Software, C2960 Software (C2960-LANBASE-M), Version 12.2(35)SE5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Thu 19-Jul-07 20:06 by nachen
Image text-base: 0x00003000, data-base: 0x00D40000
BOOTLDR: C2960 Boot Loader (C2960-HBOOT-M) Version 12.2(25r)SEE1, RELEASE SOFTWARE (fc1)
HOSTNAME uptime is 1 day, 54 minutes
System image file is "flash:c2960-lanbase-mz.122-35.SE5/c2960-lanbase-mz.122-35.SE5.bin"
cisco WS-C2960-24TC-L (PowerPC405) processor (revision E0) with 61440K/4088K bytes of memory.
Processor board ID FOC1144Z25R
2 Virtual Ethernet interfaces
Base ethernet MAC Address : 00:1E:49:75:B0:00
Motherboard assembly number : 73-9832-07
Motherboard serial number : FOC1143505H
Power supply serial number : AZS114103QF
Model revision number : E0
Motherboard revision number : A0
Model number : WS-C2960-24TC-L
System serial number : FOC1144Z25R
Top Assembly Part Number : 800-26671-03
Top Assembly Revision Number : B0
Version ID : V03
CLEI Code Number : COM3K00BRB
* 1 26 WS-C2960-24TC-L 12.2(35)SE5 C2960-LANBASE-M
Have you maneged to solve this problem?
I have a new switch 2960S  with SW Version 12.2(55)S and after one working moth started loosing configurantion a rebooting.
Best Regards
MC
If it's rebooting then chances are there's a crashinfo file(s).
Post the last three files.
