2960 switch is DEAD
scolema1
I have 2 2960 switches that have been TOTALLY wiped out!  They boot to rommon mode.  When the IOS gets wiped, usually I can restore it using xmodem.  However, this time when I try copy xmodem flash:filename  it says xmodem:  no such device.   So here I am with an IOS and a device that needs it with no means to transfer it.
These are used in a lab environment, so a student did this accidentally.  I just need some help!
Glenn Martin
Hello Scolema1:
I've moved this discussion to the appropriate forum for greater visibility.
Glenn Martin
