2960 vs 3560E
tsijmerrifield
Greeting,
Can anyone point me towards on side-by-side comparison of the 2960 and the 3560E and list the main differences in layman terms. Our vendor is recommending replacing all our edge switches (2960) with 3560E because of their better POE for our wireless deployment 1140/1250 AP's, and faster backplane speed. Unfortunately there is a huge cost difference and we need to justify this.
5 Replies 5
Reza Sharifi
Jon,
Take a look at this link:
http://www.ciscowebtools.com/productadvisor/
It does a pretty good job of comparioson
Reza
Joseph W. Doherty
Several notable differences between the 2960 and 3560-E; the former is L2 only, the latter supports L3. The former doesn't support 10 gig, the latter does. The former generally always doesn't guarantee either wire-speed forwarding PPS or internal bandwidth for all the ports, the latter comes very, very close. The former includes limited lifetime hardware warranty and free software updates, the latter, you'll need to purchase maintenance if you want coverage of the hardware and/or software.
The 3560-E is a much feature richer platform in many aspects vs. the 2960, but it's these features that adds so much to the unit cost. If it's just a question of POE power budget, and you're unable to use power injectors, and the additional (expensive) features aren't useful to you, you might consider buying more of the less expensive series switches with POE and perhaps not utilize all their ports.
PS:
BTW, you might also want to look at the stackable series switches, for instance the 2975 and 3750 series.
PPS:
Is the vendor making this recommendation also selling you the equipment?
Leo Laohoo
The 3560E support enhanced PoE (aka PoE+) of up to 20 watts per port. The 2960 PoE will only support up to 15.4 watts. You may need PoE+ to support 1250 with both radios operational. (Take note the emphasis on the word "may".)
HOWEVER, if you upgrade your firmware, for Autonomous IOS its 12.4(10b)JDA3 and for LWAP the firmware should be 5.0.173, the 1250 should be able to operate at 15.4 watts with both radios operational at the cost of lower MCS rates.
I know what I am talking because that's what we are using right now.
Hope this helps.
Great information. Thank-you for all the replies. This is a vendor/Cisco recommended upgrade, and with the PoE info we just need to determine if the backplane speeds warrant on upgrade for L2 switching. The only app I can foresee possible contention is streaming video.
Leo Laohoo
You have to understand that 1140 and 1250 have GigabitEthernet interface. So it's worthwhile to have the AP's connected to a Gig interface too otherwise anything less than a Gig will be a cause for bottleneck with your Wireless network.
