2960-X High CPU Usage
Bar1s
Level 4
Level 4
Hi Guys,
Recently we purchased C2960X-24TD-L. We were just trying to configure switch.
I just noticed there is high cpu rate even the nothing is connected.
Is it rates is normal ? It looks like high for me.
Software version is latest  : Cisco IOS Software, C2960X Software (C2960X-UNIVERSALK9-M), Version 15.2(2)E, RELEASE SOFTWARE (fc3)
Switch#sh pro cp sor
CPU utilization for five seconds: 22%/0%; one minute: 22%; five minutes: 22%
 PID Runtime(ms)     Invoked      uSecs   5Sec   1Min   5Min TTY Process
 159   103898654    30208477       3439  7.55%  7.53%  7.50%   0 Hulc LED Process
 180     1421446      403673       3521  0.11%  0.11%  0.11%   0 Power RPS Proces
 170     1907042      241726       7889  0.11%  0.12%  0.11%   0 HQM Stack Proces
 165         365          93       3924  0.11%  0.25%  0.08%   1 SSH Process
 190       81667      197098        414  0.05%  0.00%  0.00%   0 CDP Protocol
 253       31629     1207735         26  0.05%  0.00%  0.00%   0 ADJ background
  99       52848     6055047          8  0.05%  0.01%  0.00%   0 apm86xxx_enet_pr
 121         868     1208166          0  0.05%  0.00%  0.00%   0 HLFM aging proce
 204      287818      639086        450  0.05%  0.02%  0.00%   0 IP Input
 385      198556      725964        273  0.05%  0.02%  0.00%   0 IP SNMP
  10          37        1471         25  0.00%  0.00%  0.00%   0 WATCH_AFS
Jose Solano
Level 9
Level 9
 This utilization is expected for this platform, as we can see on the show process cpu command the interrupt level is at 0% which is indicating a good behavior and the overall is 22% which normal and there is nothing to worry about.
 The only process a bit high is Hulc LED Process. The "Hulc LED" process does following tasks:
- Check Link status on every port
- If the switch supports POE, it checks to see if there is a Power Device(PD) detected
- Check the status of the transceiver
- Update Fan status
- Set Main LED and ports LEDs
- Update both Power Supplies and RPS
- Check on system temperature status
 Hope this helps, and you should not be concern at all.
Leo
InayathUlla Sharieff
Yes its normal.
It would get settledown once your configuration is complete.
Jose Solano
Level 9
Level 9
- Update Fan status
Leo
