2960-x port up/down when Vivi box in use
aandersne
I have a Vivi box connected to a port on a 2960-X. As soon as a client connects to the Vivi the port on the switch starts going down and coming up constantly...
001120: 02:37:07: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/1, changed state to down
001121: 02:37:10: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/1, changed state to up
001122: 02:37:11: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/1, changed state to up
001123: 02:37:13: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/1, changed state to down
001124: 02:37:14: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/1, changed state to down
001125: 02:37:16: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/1, changed state to up
001126: 02:37:17: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/1, changed state to up
001127: 02:37:49: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1/0/1, changed state to down
001128: 02:37:50: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/1, changed state to down
001129: 02:37:58: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/1, changed state to up
If I plug the Vivi into a different switch (catalyst 3560) I don't see this. Is there some configuration on the switch that might cause this? The current port status is:
#sh int gi1/0/1
GigabitEthernet1/0/1 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 003c.100e.8081 (bia 003c.100e.8081)
  Description: ***WIRELESS AV VLAN***
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
     reliability 255/255, txload 3/255, rxload 1/255
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, media type is 10/100/1000BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input never, output 00:00:01, output hang never
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 23
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 8000 bits/sec, 24 packets/sec
  5 minute output rate 1260000 bits/sec, 114 packets/sec
     253099 packets input, 20011673 bytes, 0 no buffer
     Received 1069 broadcasts (1009 multicasts)
     1 input errors, 1 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 1009 multicast, 0 pause input
     923791 packets output, 1028133936 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
     0 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
Cheers
Ash
Leo Laohoo
On the 2960X interface, use the command "10 100 auto".
7 Replies 7
Leo Laohoo
Thanks Leo,
Forcing the speed to 10 stopped the flap.
Cheers
Ash
Speed 10 100 auto is not actually a command for Cisco IOS , do you mean enter the commands:
Speed 10
Duplex full
-Pete
Hi Pete,
I just entered "speed 10", left duplex at auto and the link started behaving.
Cheers
Ash
Thanks Ash, Going to give it a try now !
-Pete
Hi Ash,
That certainly stopped the link flap, but I would like to have a faster speed than 10mbits/sec on the Vivi due to wanting to stream HD video to the device.
So I contacted Vivi support about this issue, and they pointed me to this bug: CSCus35889. Apparently its an issue with EEE (Energy Efficient Ethernet) on some 2960X switches. I did a little testing and in my environment found the problem presented on any switch later than hardware revision 2.
The solution is very easy, you apply this command to the port that the Vivi is plugged into, and the problem goes away:  no power efficient-ethernet
This worked very nicely for me, with the port signalling up at 100mbits/sec and no more link flap but your mileage may vary.
-Pete
Thanks Pete,
Thats a much better solution! It definitely felt dirty throttling the link. I must have drawn the short straw with vivi support ;)
Cheers
Ash
