2960-X. Problem with both local and remote SPAN
hoffa2000
Level 3
Level 3
Hi all
I'm trying to set up some SPAN and RSPAN on two directly connected 2960-Xs and get a problem half way through.
The relevant config is
Remote SPAN VLANs
999
Switch 1
monitor session 1 source interface Gi1/0/4
monitor session 1 destination remote vlan 999
Switch 2
monitor session 1 source interface Gi1/0/8 - 9
monitor session 1 source interface Gi2/0/8 - 9
monitor session 1 filter vlan 173
monitor session 2 destination interface Gi2/0/21
monitor session 2 source remote vlan 999
I've got wireshark running on a PC connected to switch 2 port g2/0/21 and servers I need to monitor on switch 1 port g1/0/4, switch 2 g1/0/8-9 and switch 2 g2/0/8-9. Pretty simple setup I thought and if I run a wireshark on virtual PC that monitors VLAN 999 I see the traffic I need.
However not on the PC connected to port 2/0/21, that PC only sees the traffic coming in from switch 1, none of the traffic generated locally on switch 2. Making g2/0/21 on switch 2 destination port for both RSPAN and local SPAN doesn't work so how would I proceed? Is there something I've forgotten.
Fredrik
Boris Uskov
Level 4
Level 4
try the following config on Switch 2:
monitor session 1 source interface Gi2/0/8 - 9 monitor session 1 source remote vlan 999 monitor session 1 filter vlan 173 monitor session 1 destination interface Gi2/0/21
Sorry, that doesn't work. I'm not allowed to have both remote SPAN and local SPAN as source in the same session.
/Fredrik
Yes, you are right. I made a mistake. The similar situation is described here:
https://supportforums.cisco.com/discussion/11094496/span-rspan
It seems, that you are not able to perform your task with the only one SPAN destination. You have to use two destinations and two different collecors: the first collector for Switch1's ports, and the second collector for Switch2's ports.
Sorry again for incorrect suggestion.
I think it won't work. Here is article from cisco.com - http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960x/software/15-0_2_EX/network_management/configuration_guide/b_nm_15ex_2960-x_cg/b_nm_15ex_2960-x_cg_chapter_0111.html#ID199
Destination port can participate in only one SPAN session at a time (a destination port in one SPAN session cannot be a destination port for a second SPAN session).
and
Destination port can be any Ethernet physical port.
