2960-X Web Console gone after FW update to c2960x-universalk9-tar.152-4.E8
nem8
Greetings,
After updating the switch through the web console with c2960x-universalk9-tar.152-4.E8.tar we no longer have the Web Console.
It initially gave a 404, but after reboot of switch it just loops back to the "Cisco Systems" default web page.
Any help is appreciated!
6 Replies 6
Mark Malone
The CPS software which is included in the .tar maybe corrupt and need to be re-added , you can add the file separately , also check the directory for the .tar file and see if its in the switch flash
https://software.cisco.com/download/home/284795754/type/286310882/release/01.06.00
Thanks for pointing me in the right direction. I managed to download the CCP, setup tftp on my computer, copy the tar file and extract it on switch. It is now working as expected.
Where exactly did you extract the tar files? Onto the root of Flash?  I did this using TFTP and its still not working. Not sure if/how to extract into a sub directory...
Leo Laohoo
Post the complete output to the command "dir flash:c2960x*".
I managed to fix it in the first switch by following the link posted above.
The output by switch 2, which i havent touched yet is:
2960X#dir flash:c2960x*
Directory of flash:/c2960x*
Directory of flash:/c2960x-universalk9-mz.152-4.E8
    7  -rwx         687   Jul 8 2019 12:44:48 +02:00  info
    8  drwx        6144   Jul 8 2019 12:44:48 +02:00  html
  693  -rwx      202755   Jul 8 2019 12:46:54 +02:00  dc_default_profiles.txt
  694  -rwx    24359936   Jul 8 2019 12:46:58 +02:00  c2960x-universalk9-mz.152-4.E8.bin
122185728 bytes total (91395072 bytes free)
2960X#
Im curious as to why CCP is not part of the IOS update available for the switch tho, or if i really did something wrong/got a bad file when updating?
good stuff :)
