2960g-24tc-l internal power supply pinout / voltage check
jasonkd7tqn
Hi there,
I had a bad power surge yesterday that took out a 2960g switch and the APC UPS that it was connected too. when plugged in the fan comes on and the syst light stays amber and the rps, stat, duplex. and speed light stay lit and the port lights for ports 21-24 stay lit. plugging it into the console on boot I cant even see rommon, so i dont think its even booting. I would like to find a pinout and voltage guide for the connector comming off the power supply so I can check the voltages coming off the power supply to tell if it is a bad PSU or if it took out the main board.
thanks.
Jason Hill
Gregory Snipes
Level 4
Level 4
I know it's not exactly what you are looking for, but if this switch was pluged into an APC UPS, thier equipment protection policy should replace it regardless of what is wrong with it. Here are some intructions on how to file an EPP claim.
thanks for that info, Ill look into that, id still like to find out what exactly happened to this thing.
