2960g Amber Lights
Brickman7713
I recently bought a used catalyst 2960G 48 port switch but when I turn it on the 4 status lights and gigabit link lights immediately turn amber and stay solid amber. No console output either. Is it dead? Thanks in advance.
Leo Laohoo
If no console output, the appliance is surely dead.
Ok thanks for the reply, anyway at all to revive it?
You could try with pressing the mode button on power up:
https://www.cisco.com/c/en/us/support/docs/switches/catalyst-2950-series-switches/12040-pswdrec-2900xl.html
It does sound like its knackered though...
