10-09-2017 12:37 PM - edited 03-08-2019 12:18 PM
I need to find compatible 1Gb Copper SFPs for the 2960S-48FPD-L.
According to this -
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960/hardware/installation/guide_stack/2960SHIG/HIGOVERV.html#wp1250224
The only SFPs supported for the 48FPD-L are Fiber based. I've found other sites claim the GLC-T is compatible although not according to that matrix.
10-09-2017 12:56 PM
See the compatibility matrix for 2960s series. That model does not seem to support GLC-T
https://www.cisco.com/c/en/us/td/docs/interfaces_modules/transceiver_modules/compatibility/matrix/GE_Tx_Matrix.html#_Toc494700202
Log in to Community
