2960S and GLC-T
ooroncoym
I have a question, Does the new switch 2960-S support GLC-T module in the uplink SFP slot?
I find in the data sheet the following:
Cisco Catalyst 2960-S and 2960  with SFP-based ports:
• 1000BASE-T SFP-based ports**:  RJ-45 connectors, 4-pair Category 5 UTP cabling
**  1000BASE-T not supported on Cisco Catalyst 2960-S  switches.
Please, I need confirmation.....
6 Replies 6
Leo Laohoo
Yes it does.  I have a few installed.
vragotha
Level 3
Level 3
Vijay - could you please verify that the GLC-T is supported?  There are multiple conflicting documents.  I have also found conflicts in the Netformx tool where just two weeks ago the GLC-T was a selectable option and could be verified where today it is not?  Both the MLC and CT do not have this option to select the SFPs.
As it stands - i would have to order these as seperate items.
Thanks, Steve
I can confirm it works because I have several 2960S-24PD that have GLC-T in them.
wholemans
I can confirm that it works and that cisco DOES NOT support this, see also the thread i started about this an hour ago.
Cisco gave us the message that it might work but that they DO NOT support this, so whatever problem you get in a config that has these SFP, you risk to get no support.
Wim Holemans
Network Services
University of Antwerp
I made the question, the respond of the Cisco Systems Engineers,is the following:
"Yes, the GLC-T is supported on the 2960S.  The data sheet hasn’t been updated.  However, the hardware installation guide does list the GLC-T. Here is the list of supported 2960S models for the GLC-T SFP:
          Catalyst 2960S-48FPS-L
          Catalyst 2960S-48LPS-L
          Catalyst 2960S-24PS-L
          Catalyst 2960S-48TS-L
          Catalyst 2960S-24TS-L
          Catalyst 2960S-48TS-S
          Catalyst 2960S-24TS-S "
