2960s IOS Upgrade Issue
Mario Musquiz
I have a issue when i try to upgrade the IOS of WS-C2960S-48TS-L, the curretn version is 12.2(58)SE2 , the verison im trying to upgrate to is 15.2.SE6.
I do the "archive tar /xtract tftp" command to extract all the files to the flash, then i do the "boot system flash:"  command to change to the new but when i reboot the switch it loads the new ios then loads the old ios and boot using the old ios, how can i change to ignore the old ios ?
17 Replies 17
Here i am again...and with new weird news.
I've made new tests and analisys on my six WS-2960S-48LPS-L.
Cables are ok (said by TDR).
Five on six no way to upgrade, from CLI, upper 15.0.1-SE. This is the newest working IOS i found, tested:
c2960s-universalk9-mz.150-2.EX
c2960s-universalk9-mz.150-2.SE6
c2960s-universalk9-mz.150-2.SE6  <-- suggested by Cisco
c2960s-universalk9-mz.150-2.SE7
c2960s-universalk9-mz.152-2a.E1
no way to boot, always the same error i've already posted.
Tried to format the rom also, always same things.
Anyway with 15.0.1-SE that should have fixed the poe problems, poe doesnt work...So i guess it's a hardware problem. Well ...5/6... i must say i have really bad luck...
But now, give me your attention please.....
One of them works, every port do its job with my voip cisco 7912 phones, with an old IOS also (12.2.58-SE2). So, i checked if it is a 2960S-48LPS-L for sure, serial number on case is the same i have on the package. It says it's a LPS-L. So, from CLI, i tried a show version....look at this:
Cisco IOS Software, C2960S Software (C2960S-UNIVERSALK9-M), Version 12.2(55)SE8, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Wed 26-Jun-13 11:40 by prod_rel_team
Image text-base: 0x00003000, data-base: 0x01B00000
ROM: Bootstrap program is Alpha board boot loader
BOOTLDR: C2960S Boot Loader (C2960S-HBOOT-M) Version 12.2(53r)SE, RELEASE SOFTWARE (fc3)
Vigili uptime is 6 days, 21 hours, 54 minutes
System restarted at 12:01:56 UTC Wed Apr 1 2015
System image file is "flash:/c2960s-universalk9-mz.122-55.SE8/c2960s-universalk9-mz.122-55.SE8.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C2960S-48FPS-L (PowerPC) processor (revision H0) with 131072K bytes of memory.
Processor board ID FOC1726Z0GN
Last reset from power-on
1 Virtual Ethernet interface
1 FastEthernet interface
52 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 84:80:2D:0D:F8:00
Motherboard assembly number     : 73-11908-09
Power supply part number        : 341-0393-02
Motherboard serial number       : FOC183811TD
Power supply serial number      : LIT183101SG
Model revision number           : H0
Motherboard revision number     : A0
Model number                    : WS-C2960S-48LPS-L
Daughterboard assembly number   : 73-11933-04
Daughterboard serial number     : FOC18376CNB
System serial number            : FOC1726Z0GN
Top Assembly Part Number        : 800-30945-04
Top Assembly Revision Number    : C0
Version ID                      : V04
CLEI Code Number                : COMGZOOARD
Daughterboard revision number   : A0
Hardware Board Revision Number  : 0x01
Switch Ports Model              SW Version            SW Image
*    1 52    WS-C2960S-48FPS-L  12.2(55)SE8           C2960S-UNIVERSALK9-M
now i'm really confused...
I called Cisco, gave them the serial number and they confirmed must be a LPS-L.
Ideas?
rakeshvelagala
Level 3
Level 3
first remove the existing statements
#no boot system
Then the IOS  want to boot
#boot system flash:xxxxxx
Thanks rakeshvelagala,
i'll try asap and let you know.
