2960s Stack IOS Upgade - Reboot Loop
bartosikr1
Frequent Visitor
Frequent Visitor
All - Tried to upgrade 5 2960s Stacks from IOS 15.0(2a)SE9 to the following IOS -
c2960s-universalk9-mz.152-2.E7.bin
Once we did this we were faced with a continuous switch stack reboot on all 5 stacks with the below error output.
Has anyone experienced this issue? Is this ver. not compatible with the 2960s or could this be a bug in the IOS?
19:00:42 GMT Sun Jan 1 2006: Unexpected exception to CPUvector 2000, PC = 235615C
-Traceback= 0x235615Cz 0x16A92A8z 0x16DD360z 0x169D90Cz 0x21A936Cz 0x21A56ECz
Writing crashinfo to flash:/crashinfo_ext/crashinfo_ext_10
=== Flushing messages (19:00:50 GMT Sun Jan 1 2006) ===
Buffered messages:
Queued messages:
*Jan  1 19:00:50: %SYS-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
*Mar  1 00:00:23.236: Read env variable - LICENSE_BOOT_LEVEL =
*Jan  2 00:00:00.576: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = c2960s_lanbase Next reboot level = lanbase and License = lanbase
*Jan  2 00:00:25.695: %STACKMGR-4-SWITCH_ADDED: Switch 1 has been ADDED to the stack
*Jan  2 00:00:28.479: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to down
*Jan  2 00:00:28.479: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to down
*Jan  2 00:00:28.605: %SMI-5-CLIENT:  Smart Install Client feature is enabled. It is recommended to disable the Smart Install feature when it is not actively used. To disable feature execute 'no vstack' in configuration mode
*Jan  2 00:00:30.634: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
*Jan  1 19:00:38: %SYS-6-CLOCKUPDATE: System clock has been updated from 00:00:38 UTC Mon Jan 2 2006 to 19:00:38 GMT Sun Jan 1 2006, configured from console by console.
*Jan  1 19:00:38: %SYS-6-CLOCKUPDATE: System clock has been updated from 19:00:38 GMT Sun Jan 1 2006 to 19:00:38 GMT Sun Jan 1 2006, configured from console by console.
*Jan  1 19:00:41: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan501, changed state to down
*Jan  1 19:00:41: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan601, changed state to down
*Jan  1 19:00:42: %SYS-5-CONFIG_I: Configured from memory by console
*Jan  1 19:00:42: %STACKMGR-5-SWITCH_READY: Switch 1 is READY
*Jan  1 19:00:42: %STACKMGR-4-STACK_LINK_CHANGE: Stack Port 1 Switch 1 has changed to state DOWN
*Jan  1 19:00:42: %STACKMGR-4-STACK_LINK_CHANGE: Stack Port 2 Switch 1 has changed to state DOWN
Cisco IOS Software, C2960S Software (C2960S-UNIVERSALK9-M), Version 15.2(2)E7, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2017 by Cisco Systems, Inc.
Compiled Wed 12-Jul-17 12:40 by prod_rel_team
Debug Exception (Could be NULL pointer dereference) Exception (0x2000)!
SRR0 = 0x01822960  SRR1 = 0x00029230  SRR2 = 0x0235615C  SRR3 = 0x00029230
ESR = 0x00000000  DEAR = 0x00000000  TSR = 0x84000000  DBSR = 0x01000000
CPU Register Context:
Vector = 0x00002000  PC = 0x0235615C  MSR = 0x00029230  CR = 0x40224048
LR = 0x016A92A8  CTR = 0x00000040  XER = 0x00000014
R0 = 0x00000003  R1 = 0x05ECDD98  R2 = 0x00000000  R3 = 0x00000000
R4 = 0x05ECDDEC  R5 = 0x00000041  R6 = 0x00004800  R7 = 0x00000020
R8 = 0x00099000  R9 = 0x033A0000  R10 = 0x033C0000  R11 = 0x033C0000
R12 = 0x000101F2  R13 = 0x00000280  R14 = 0x20208044  R15 = 0x00000001
R16 = 0x05F5EBF0  R17 = 0x00001DA4  R18 = 0x05ECDDAC  R19 = 0x00000000
R20 = 0x05EF7EEA  R21 = 0x00000001  R22 = 0x00000000  R23 = 0xFFFFFFFF
R24 = 0x05ECDDEC  R25 = 0x00000000  R26 = 0x05ECDDEC  R27 = 0x05EF7AF4
R28 = 0x00000003  R29 = 0x00000385  R30 = 0x05EF7EE0  R31 = 0x05EF9624
Stack trace:
PC = 0x0235615C, SP = 0x05ECDD98
Frame 00: SP = 0x05ECDF30    PC = 0x016A91C0
Frame 01: SP = 0x05ECDFF0    PC = 0x016DD360
Frame 02: SP = 0x05ECE0D8    PC = 0x0169D90C
Frame 03: SP = 0x05ECE0E0    PC = 0x021A936C
Frame 04: SP = 0x00000000    PC = 0x021A56EC
Mark Elsen
 - If it's stack related , then examine this , by breaking the stack and try this on  a single box only; check if the problem persists. If so roll back or try another IOS version, more recent or even gold-starred, if  possible.
M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Mark Elsen
M.
Do not, I repeat, Do not use 15.2.2 E7 on a 2960s.  Although it shows available, it will do a continuing boot load on the switch.  Only way out of it on a 2960s is to Rommon and Xmodem the previous code.  In my case 15.2.2 E5 works fine.  On a stack of 4 and production environment, this ended up being a long night!
Leo Laohoo
Try a different version. Looks like an IOS bug.
Once this is stable, contact TAC and get them to analyze this.
