2960s VLAN routing
stace
Hi, I could use some help with an issue I'm experiencing setting up a lab environment, just getting into learning some networking.  Using a 2960S-24PD-L switch, running the 'lanbase-routing' template and IOS is 15.2.
I have created a few VLANs (vlan10, vlan 20 & vlan100) & SVIs, 'ip routing' has been run and all, well most, inter-vlan routing is working.  VLAN100 (IP 10.100.0.254/16) is on G1/0/24, connected to a TMG server IP 10.100.0.1/16.  On the TMG server I added the routes and can connect to all vlans on the switch.  The problem is any hosts on vlan10 or vlan20 can't connect to the TMG server; I can ping the SVI 10.100.0.254, but not the TMG at 10.100.0.1.  All ports are configured as access ports and routing between the vlans is otherwise working.  So in summary, TMG-->switch is working, switch-->TMG not so much :0).
Not sure what I'm missing but wouldn't be surprised if it's something simple I overlooked, still very much a network noob!!  Any help is appreciated, I can post configs tomorrow when I get back to the switch.
Thanks.
What is 10.100.0.1?
is it a firewall?
Reza Sharifi
Do hosts in vlan 10 and 20 have the correct default gateways?
Also, make sure the hosts don't have firewall software installed.  That could prevents them from pinging and being pinged.
Thanks Reza.  The hosts are using the SVI address, so hosts on VLAN10 use 172.16.10.254/24 for the GW, and hosts on VLAN20 use 172.16.20.254/24 for the GW.  VLAN100 GW is 10.100.0.254/16.  From the switch itself I'm unable to ping the TMG at 10.100.0.1/16.  I thought it might be a firewall on the TMG but Windoze fwall is off and I've added a rule to allow incoming pings from the internal side.  I can't seem to get this working :0(
sw01#sh run
Building configuration...
Current configuration : 3139 bytes
! Last configuration change at 23:21:36 EST Sat Jul 12 2014
! NVRAM config last updated at 23:08:52 EST Sat Jul 12 2014
version 15.0
no service pad
service sequence-numbers
hostname sw01
boot-start-marker
boot-end-marker
enable secret
enable password
no aaa new-model
clock timezone EST -5 0
switch 1 provision ws-c2960s-24pd-l
ip routing
spanning-tree mode rapid-pvst
vlan internal allocation policy ascending
interface FastEthernet0
 no ip address
 no ip route-cache
 shutdown
interface GigabitEthernet1/0/1 - 21
interface GigabitEthernet1/0/22
 switchport access vlan 10
 switchport mode access
interface GigabitEthernet1/0/23
 switchport access vlan 20
interface GigabitEthernet1/0/24
 switchport access vlan 100
interface GigabitEthernet1/0/25
interface GigabitEthernet1/0/26
interface TenGigabitEthernet1/0/1
interface TenGigabitEthernet1/0/2
interface Vlan1
 no ip address
 shutdown
interface Vlan10
 ip address 172.16.10.254 255.255.255.0
interface Vlan20
 ip address 172.16.20.254 255.255.255.0
interface Vlan100
 ip address 10.100.0.254 255.255.0.0
ip http server
ip http secure-server
ip route 0.0.0.0 0.0.0.0 10.100.0.1
line con 0
line vty 0 4
 password
 login
line vty 5 15
 password
 login
end
sw01#
sw01#
sw01#
sw01#
sw01#ping 172.16.10.254
Sending 5, 100-byte ICMP Echos to 172.16.10.254, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/5 ms
sw01#ping 172.16.20.254
Sending 5, 100-byte ICMP Echos to 172.16.20.254, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
sw01#ping 10.100.0.254
Sending 5, 100-byte ICMP Echos to 10.100.0.254, timeout is 2 seconds:
sw01#ping 10.100.0.1
Sending 5, 100-byte ICMP Echos to 10.100.0.1, timeout is 2 seconds:
Success rate is 0 percent (0/5)
sw01#
What is 10.100.0.1?
is it a firewall?
It's a Forefront TMG 2010 server, and looks like it is the cause.  I removed it and put a Win8 host on the port and had full connectivity.  So I think my switch config is good, it's my TMG config that's not!
