Cisco 1941 router and SMB SG500 configuration issue
I am trying to configure a Cisco 1941 router with SMB SG500 switch. Configuration is fairly simple. I am using 802.1q subinterfaces on the router with vlans 1 and 10. VLAN 10 is voice vlan. Below is the config for both router and switch. I cannot get the phone to get an IP address via DHCP from the router. Not sure what I am missing. Please help!
Current configuration : 1507 bytes
! Last configuration change at 14:35:11 UTC Mon Jul 14 2014
version 15.2
service password-encryption
hostname GW_RTR_MAIN
boot-start-marker
boot-end-marker
enable secret 5 $1$wB.Y$xqn1Dm294oQ8BOS5QZlAU0
no aaa new-model
ip cef
ip dhcp pool VOICE
 network 10.1.10.0 255.255.255.0
 default-router 10.1.10.1
 dns-server 8.8.8.8 8.8.4.4
no ipv6 cef
license udi pid CISCO1941/K9 sn FTX182482GA
redundancy
interface Loopback0
 ip address 199.199.199.199 255.255.255.255
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 no ip address
 duplex auto
 speed auto
interface GigabitEthernet0/1
 no ip address
 duplex auto
 speed auto
interface GigabitEthernet0/1.5
 description USER VLAN
 encapsulation dot1Q 1 native
 ip address 10.1.5.1 255.255.255.0
interface GigabitEthernet0/1.10
 description VOICE VLAN
 encapsulation dot1Q 10
 ip address 10.1.10.1 255.255.255.0
ip forward-protocol nd
no ip http server
no ip http secure-server
SWITCH CONFIG is in the attached screenshots.
The router is connected on port 24 of the switch.
Thanks.
2 Accepted Solutions
In the last picture you uploaded (capture.png), vlan 10 is listed as forbidden on port 24. Is it supposed to be like that? I think it should say tagged or allowed. Check the configuration of that port.
HTH.
RS.
Emmanuel Valdez
Level 3
Level 3
On switch port 24 you have to tag the VLAN id, so change you settings from forbidden to tag like the other ports, when you connect the ip phone to the port it assigned the VLAN 10 and it is tagged for that reason the IP phone doesn´t acquired IP address.
If it was useful please rate.
Regards.
7 Replies 7
Rajeev Sharma
Hey,
Try configuring service dhcp on router.
HTH.
RS.
DHCP is configured on the router
HTH.
RS.
That did the trick! Actually I had port 24 excluded because I was following the below article. and i knew something was wrong with it since it didnt make sense to me either.
http://www.firewall.cx/cisco-technical-knowledgebase/cisco-switches/885-cisco-switches-sg500-52p.html
Thanks.
RS.
So I changed the Data VLAN to VLAN 5 on interface g0/1.5 and entered the command "encapsulation dot1q 5 native" Now again the phone doesnt get the IP address. I untagged all VLAN 5 traffic on the switch. But nothing worked. What am I missing?
Emmanuel Valdez
Level 3
Level 3
Regards.
