2960S with GLC-T
Randy Calderon
Hello Experts,
This may be a simple question for you but I wanted to make sure that this works...
We have a two WS-C2960S-48FPS-L and each of them is sitting on an office that's very close to each other. To connect both switches with a link is less than 300 feet. I want to connect this 2 switches together using the SFP ports. I want to use all the SFP ports on both switches using a GLC-T module then I will join all the SFP ports into an etherchannel so theoritically, I will have 4 GB throughput. Also, I will be using CAT 6A cables for this connection.
Now, my question is, to your knowledge. Will this work?
Thank you,
Randy C.
Hi Randy,
I guess it works.
Madhu
