2960X and routing
moussa.malqui1
Hi all,
2960-X switchs they are support static routing?
Best regards,
MM
It can support static routing only, not dynamic routing. Although it is often used as layer 2.
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960x/software/15-0_2_EX/routing/configuration_guide/b_rt_152ex_2960-x_cg/b_rt_152ex_2960-x_cg_chapter_010.html
Also check this link for 2960XR
http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-2960-x-series-switches/qa_c67-728348.html
I have tested one of my  WS-C2960X-24TD-L and it allow static routing.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
thanks Julio
It was a pleasure,
Have a great day
