2960X Macro Condition on Interface Description
baumer-ts
Hi all,
I'd like to create a macro which changes the port mode to multi-auth and back to multi-domain only if doesn't have a certain interface description. My approach looks like follows:
macro auto execute MULTI_AUTH_TEST {
if [[ $LINKUP == YES ]]; then
conf t
 interface $INTERFACE
 macro description $TRIGGER
 if [[ $DESCRIPTION != miniswitch ]]; then
 authentication host-mode multi-auth
 fi
 exit
fi
if [[ $LINKUP == NO ]]; then
conf t
 no macro description $TRIGGER
 authentication host-mode multi-domain
 fi
 exit
fi
Unfortunately this doesn't work. Is there even a variable for the interface description to use in macros? I couldn't find any list about possible built in variables at all.
Best Regards
Micha
0 Replies 0
