QSFP-4X10G-AOC10M
ayakoleb
Hello Colleagues ,
I have a cable QSFP-4X10G-AOC10M that i need to connect the 40G port to 3850-48xs and use 2 of the 10G ends , 1x10G to be connected to 3850-24xs and 1X10G to a controller 5520?
datasheet stated that These breakout cables connect to a 40G QSFP port of a Cisco switch on one end and to four 10G SFP+ ports of a Cisco switch on the other end
the question is , for the 40G interface , How will be the configration?
thanks to Help .
Reza Sharifi
According to the data matrix sheet, the AIR-5520 supports this cable.
See the link and just search for 5520.
https://tmgmatrix.cisco.com/?si=5520
thanks for your reply ,
yes , I checked that controller support this cable ,
my question more related to the configartion for the cable .as from the 40G  interface , how i shall configure two different 10G interfaces with different configrations .
