2960X not providing PoE to none Cisco End Points
PAR
Hello
We have a new 2960X switch but it isn't sending power to none Cisco end point. We can connect a Cisco access point and it provides power as normal, but when I connect the door access control unit or a Mitel telephone I get the following error message: -
May 13 12:17:47.215: %ILPOWER-7-DETECT: Interface Gi1/0/1: Power Device detected: IEEE PD
May 13 12:17:48.095: %ILPOWER-5-POWER_GRANTED: Interface Gi1/0/1: Power granted
May 13 12:17:48.410: %ILPOWER-5-IEEE_DISCONNECT: Interface Gi1/0/1: PD removed
I have tried it on various ports and it appears to be the same.
This is the switch details: -
WS-C2960X-48FPD-L 15.2(4)E8 C2960X-UNIVERSALK9-M
I have connected the none Cisco end points to a Cisco 2960S and they work fine.
Is it a firmware issue?
Appreciate any advice.
Paul.
8 Replies 8
Martin L
1. could be none left , aka no power is available in terms of Watts for that device.  if other devices taken all the power, none is left for next device. check power available / remaining with show power inline command
2. check cable to that device.  from switch u can run command cable test tdr interface Gix/y
in terms of Gigabit, all 4 pairs - all 8 wires- must be correctly connected/terminated.
3. End-device Or port is failing.  try different end device on same port and/or try different port
Regards, ML
**Please Rate All Helpful Responses **
Thanks for the response.
I'm using a patch lead direct from switch to end point and I have tried various patch leads. I use the same patch lead to connect the Cisco access point and it works fine. Also when I test with a 2960S switch I'm using the same patch lead and it works.
This is the only device connected to the switch, its currently in our test area.
Paul.
PAR
Further update.
I have tried upgrading and downgrading firmware but still have the issue. I have also upgraded the firmware of the 2960S and the end device works fine.
I did notice the PoE LED is flashing orange.
Any advice much appreciated.
thanks.
pkumari4
Hello Paul,
From your description I can see that the problem is only with the other PD, cisco PD is working fine on the same switch.
Was this end device working prior to this on the problematic switch?
From the provided logs I could not find much.
Could you please try to provide the static power to the port where you are connecting your non-working PD.
switch (config)#interface <interface id>
switch (config-if)#power inline port 2x-mode
switch (config-if)#shut
switch (config-if)#no shut
Before executing the above command enable the below debugs on the switch so that we will be able to find the root cause in the logs.
debugs ilpower port
debug ilpower powerman
debug ilpower controller
Also, try to change the port on the same switch and then check, these steps you need to follow in order to isolate the issue. If the same switch is able to provide the power to the Cisco PD then there might be some other problem.
Priyanka
Thank you for your reply Priyanka
This a new door access control unit and a new switch, but I have tried on another 2960X and it still doesn't work, but does work on the 2960S switch. I have also tried other door access control units and I get the same results.
I have applied the command you mentioned and this is the debug output.
May 15 08:33:24.113: ILP CLI 'no shut' handling ( Gi1/0/1 ) Okay
May 15 08:33:24.116: ILP Start PHY Cisco IP phone detection ( Gi1/0/1 ) Okay
May 15 08:33:24.116: ILP CLI 'no shut' handling ( Gi1/0/1 ) Okay
May 15 08:33:24.116: ilpower_notify_lldp_tlv: lldp power class tlv:
May 15 08:33:24.116: (curr/prev) pwr value 15400/0
May 15 08:33:24.116: ilpower_powerman_power_available_tlv: about sending patlv on Gi1/0/1
May 15 08:33:24.116: req id 0, man id 1, pwr avail 0, pwr man -1
May 15 08:33:24.120: ILP State_Machine ( Gi1/0/1 ): State= ILP_SHUT_OFF_S, Event= CLI_START_DETECT_EV
May 15 08:33:24.120: **** Instance 0 : Sub Address 0 *****
May 15 08:33:24.120: ***************************************
May 15 08:33:24.120: ILP Power apply to ( Gi1/0/1 ) Okay
May 15 08:33:24.120: ILP Start Power Controller phone detection ( Gi1/0/1 ) Okay
May 15 08:33:24.120: ILP Start PHY Cisco IP phone detection ( Gi1/0/1 ) Okay
May 15 08:33:24.120: ILP State_Machine ( Gi1/0/1 ): State= ILP_DETECTING_S, Event= CLI_START_DETECT_EV
May 15 08:33:25.095: ILP State_Machine ( Gi1/0/1 ): State= ILP_DETECTING_S, Even                  t= IEEE_CLASS_DONE_EV
May 15 08:33:25.095: **** Instance 0 : Sub Address 0 *****
May 15 08:33:25.095: ***************************************
May 15 08:33:25.095: %ILPOWER-7-DETECT: Interface Gi1/0/1 Power Device detected: IEEE PD
May 15 08:33:25.095: Ilpower PD device 3 class 7 from interface (Gi1/0/1)
May 15 08:33:25.095: ilpower new power from pd discovery Gi1/0/1, power_status ok
May 15 08:33:25.095: Ilpower interface (Gi1/0/1) power status change, allocated power 15400
May 15 08:33:25.095: ilpower_notify_lldp_tlv: lldp power class tlv:
May 15 08:33:25.095: (curr/prev) pwr value 15400/0
May 15 08:33:25.095: ilpower_notify_lldp_power_via_mdi_tlv Gi1/0/1 pwr alloc 15                  400
May 15 08:33:25.095: Gi1/0/1 AUTO PORT PWR Alloc 130 Request 130
May 15 08:33:25.095: Gi1/0/1: LLDP NOTIFY TLV:
    (curr/prev) PSE Allocation: 13000/0
    (curr/prev) PD Request    : 13000/0
    (curr/prev) PD Class      : Class 4/
    (curr/prev) PD Priority   : low/unknown
    (curr/prev) Power Type   : Type 2 PSE/Type 2 PSE
    (curr/prev) mdi_pwr_support: 7/0
    (curr/prev Power Pair)     : Signal/
    (curr/prev) PSE Pwr Source : Primary/Unknown
May 15 08:33:25.095: ILP Power apply to ( Gi1/0/1 ) Okay
May 15 08:33:25.095: ILP Power Accounting REQ_PWR ( Gi1/0/1 ) Okay sys_used=15400
May 15 08:33:25.996: ILP State_Machine ( Gi1/0/1 ): State= ILP_PD_DETECTED_S, Event= IEEE_PWR_GOOD_EV
May 15 08:33:25.996: **** Instance 0 : Sub Address 0 *****
May 15 08:33:25.996: ***************************************
May 15 08:33:25.996: %ILPOWER-5-POWER_GRANTED: Interface Gi1/0/1: Power granted
May 15 08:33:26.115: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/1, changed state to down
May 15 08:33:26.259: ILP State_Machine ( Gi1/0/1 ): State= ILP_LINK_UP_S, Event= IEEE_PD_REMOVAL_EV
May 15 08:33:26.259: **** Instance 0 : Sub Address 0 *****
May 15 08:33:26.259: ***************************************
May 15 08:33:26.259: ilpower delete power from pd linkdown Gi1/0/1
May 15 08:33:26.259: Ilpower interface (Gi1/0/1), delete allocated power 15400
May 15 08:33:26.259: Ilpower interface (Gi1/0/1) setting ICUT_OFF threshold to 0                  .
May 15 08:33:26.259:  ilpower_notify_lldp_power_via_mdi_tlv Gi1/0/1 pwr alloc 0
May 15 08:33:26.259: Gi1/0/1 AUTO PORT PWR Alloc 130 Request 130
May 15 08:33:26.259: Gi1/0/1: LLDP NOTIFY TLV:
May 15 08:33:26.259: ilpower_notify_lldp_tlv: llshdp power class tlv:
May 15 08:33:26.259:     (curr/prev) pwr value 15400/0
May 15 08:33:26.259: ILP Power apply to ( Gi1/0/1 ) Okay
May 15 08:33:26.259: ILP Start PHY Cisco IP phone detection ( Gi1/0/1 ) Okay
May 15 08:33:26.259: %ILPOWER-5-IEEE_DISCONNECT: Interface Gi1/0/1: PD removed
May 15 08:33:26.259: ILP Power Accounting RELEASE_PWR ( Gi1/0/1 ) Okay, pwr_used= 0
May 15 08:33:26.259: ILP State_Machine ( Gi1/0/1 ): State= ILP_DETECTING_S, Event= ILP_POWER_POLICE_DISABLE_EV
May 15 08:33:26.259:**** Instance 0 : Sub Address 0 *****
May 15 08:33:27.936: ILP State_Machine ( Gi1/0/1 ): State= ILP_DETECTING_S, Event= IEEE_CLASS_DONE_EV
May 15 08:33:27.936: **** Instance 0 : Sub Address 0 *****
May 15 08:33:27.936: ***************************************
Thanks Paul.
pkumari4
Hello Paul,
Here we need to first understand the class which the nonworking PD is supporting. If it is working on one 2900S and not on 2900-X then there might be the platform-specific and the device compatibility issue.
What I see wrong is the detection of the equipment, since it says that it is a "PD 3 class 7 device" connected in the interface
The switch is classifying it as PD 3 class 7 technically I never have seen anything after class 4 in cisco switch.
You can see here the PD is requesting 13W and the switch (PSE) is allocating the same. So the LLDP negotiation for me is working fine.
It looks that immediately after power is granted, we see a PD removal event
causing the link to go down.
May 15 08:33:26.115: %LINK-3-UP DOWN: Interface GigabitEthernet1/0/1, changed state to down
So to summarize this I think you need to use an external power injector on the switch 2900-X for this device. For me, its more like the IEEE PD and switch compatibility issue.
Priyanka
Hello
Do you have LLDP enabled, if not enable it an see if the power consumption for that device can be discovered and negotiated.
Also, you try manually setting the power on the interface to its highest value and if it works check to see what power is being used and then decrease to that value.
sh power inline
sh power inline gig0/1 consumption
conf t
lldp run
int gig0/1
lldp receive
lldp transmit
power inline consumption 15400 or 30000 (15.4 or 30 watts- switch depending)
Kind Regards
Paul
Thanks Paul,
I have enabled LLDP and still the same issue.
We are trying to connect to a Paxton Net2 door controller, which does state it supports 802.3af and at, so not not why it works on a 2960S switch but not a 2960X.
regards
Paul.
