2960X Stack and Firewall Standby Issue
Mike Wagner
Hi Everyone,
So, I have a pair of Cisco Firepower 4110 firewalls in an HA active/standby configuration, and a pair of edge routers with HSRP.  I needed four 10GB ports to create a L2 domain for all of the devices to be connected together.  So, I stacked a pair of 2960X switches with the latest recommended firmware, and connected a router and firewall into each switch.
After about an hour, the active firewall stops passing traffic.  I spent weeks trying to discover the root cause (thinking it was the Firepower).   I even got Cisco to send me a RMA 4110.  After no luck, I discovered that the standby firewall's virtual MAC address is not showing in the MAC address table.  I can see the MAC of the primary and secondary HSRP routers and the Active Firepower, but nothing on the standby.
Does anyone have any ideas I can try?  When I plug them all in to a 3850 with SFP+ ports, all is well and no missing MACs.  However, I don't have a second 3850 for redundancy.  I'd like to utilize the 2960X switches if possible.
Thanks!
balaji.bandi
Can you draw a small diagram of both working and not working?
also, post-show run config of cisco 2960 and version of code running.
what logs you on Cisco 2960 switch?
BB
I've attached a really bad diagram    I have a better one in Visio, but it has a bunch of other stuff on it too.
Each device is connected to a TenGigabitEthernet port.  ASR 1 to Ten1/0/1, Firepower 1 to Ten1/0/2, ASR 2 to Ten2/0/1 Firepower 2 to Ten2/0/2
Firepower 2 is the Standby unit whose MAC disappears when all of this goes awry.
The config is very basic.  Nothing except VLAN 103, switchport mode access, spanning-tree portfast on all four tengig ports.
The IOS version is 15.2.7 E6
There was nothing in the logs when this happened.
This odd, is the stack in ring ? no stack cable loose ?
i try different version lower and test it.
BB
